My amazing warranty (cont/d), and a question...
After this, the warranty company will have paid out almost $20K in repairs.
The question: what exactly went wrong that they had to replace "a set of control arms and three suspension links?" And how come I didn't notice it??
Yes, the BG injector cleaning and the oil change plus the deductible is what you are responsible for. Your total came to $632.91. The wheel bearing, a set of control arms and three suspension links with a wheel alignment were taken care of under warranty. They are covering a total of $3418.37.
Since ownership I have replaced (suspension) front shocks, tie rod ends , rear stabilizer link rods & toe rod arms
On the to do list is the following
Rear lower control arm
Rear upper control arms
Front upper control arms
Regardless of km/miles it seems the oem suspension components are only good for 5-7yrs before they start to perish, suspension issues are very common in our vehicles .
winstonsalemncxk (03-31-2018)
Received 2,012 Likes
And what I'd add - noticing that you've got a 2007 - is that I didn't bring the car in for any of that. I just wanted an oil change, and to have the "mystery click" that I was hearing checked out (which apparently was a wheel bearing, which sounds odd, but the noise is gone).
After I got the car back (I did notice a difference), I went on the forum and did a little reading on suspension-related threads, and it ends up that the "rubber bits" of our suspension on these cars (boots, bushings, etc) does go at the 7-10 year mark. It's a common issue as the cars age, regardless of mileage.
Someone else picks the tab up on replacing that stuff, it's fine with me...
ajmainevents
17
08-02-2014 12:21 PM
