My annual oil service today.
So today I took the 2012 XKR for it's annual oil change. 180 mile round trip at 60-70 mph and got 23 mpg. Nice day in the mid 40's. So here is the cost from my dealer.
- Routine oil/filter and chassis lube labor $40
- C2D3670 Oil filter $48
- (8) 217DDB 0W-20 edge pro castrol oil $96
They also checked and topped all fluids. Then a multipoint maintenance inspection including checking for leaks and battery test.
I also had a NYS inspection which they did at no charge. Brake pads were all greater then 8mm and all tires greater then 8/32. So you can do the math but that's there charge.
I'm sure that some will say that's expensive for an oil change, but I look at it as being cheap insurance for the peace of mind for your XKR knowing that (1) the proper oil and filter were used; (2) a complete multipoint inspection was performed and all fluids were topped off with the proper products; (3) you battery was tested and is OK; (4) your brake pads were measured and are OK; (5) your car passed NYS inspection; and, (6) all the work was done by an authorized Jaguar dealer using qualified Jaguar.techs. It doesn't get any better than that.
Most importantly, you finally got to take a long drive on a beautiful day and (hopefully) put the top down and enjoyed the wind in your hair!
winstonsalemncxk (04-21-2018)
I'll be bringing mine in for the annual checkup at the dealer Wednesday. In addition to the oil change, state inspection, and multipoint inspection, the dealer is offering a complementary suspension and steering check. The car has not given me any problems in 10 years and 61k miles (other than the duck bill), but I like to get it up on the lift and make sure there is no visible potential problems.
Excuse my ignorance as I haven't taken my recently acquired 2010 XKR to the dealer ...yet.
Thanks in advance,
Dave
4Holer
04-20-2016 11:07 AM
orangeblossom
02-28-2016 04:35 PM
