My dealer Oil change and shop rate
OK so I have a breakdown of my dealers rate for an oil change on a 2010-2015 XKR. This dealer is in Albany NY. their normal shop rate is $126 per hour. The oil change is as follows:
Part No. C2D3670 , Filter Oil $46.62
Part No. 06258 Castrol 5W-20 AJ V8 Gen III $9.51/qt x8 = $76.08
Labor $39.95
SubTotal $162.65
Tax $13.02
Total $175.67
Just an FYI
Labor $39.95
SubTotal $162.65
Tax $13.02
Total $175.67
Just an FYI
Castrol 5W-30 Walmart - $25.17 for 5 qt bottle = $51.35
Jag Oil Filter - = $26
Total is $78 for parts if bought yourself.
Actual labor time should not exceed 1/2 hour for any indi or dealership. Sounds like you actually got a good price considering it was a dealership... as we've seen here oil change rates can vary GREATLY. If they're decent they will install those very same parts for you purchased elsewhere as long as it is OEM parts and approved oil. I don't recall if the 5.0L needed a suction or if it has the oil pan plug, if it's a suction only then maybe 15 min job. Though that's a good rate for a dealership I still stand by my belief that dealership work on an actual rate of $400/hr - $77 for parts, $100 labor for their 15 mins = $400/hr actual
Jag Oil Filter - Amazon w/ free shipping = $26
Do you have a Home Depot near you?
Castrol 5W30 @ Home Depot - $25.77 for 5qts you need 2 so $51.50 - I was surprised to see that most Home Depot's now have a decent auto section. Those are standard prices not the deals that Walmart and others often have. Plus you'll have 2.7qts left over as the car uses 7.2-7.3 qts
Oil filter was $26 at Amazon, didn't look elsewhere perhaps could be found cheaper. These are the same parts used not lesser aftermarket stuff (official OEM Jaguar on the box). Thats ALL the parts needed which comes to $76 purchased without the huge mark-up. Your total was $175.67 - $76 parts purchase price elsewhere that leaves labor of $100. The job takes maybe 15 mins at most using their suction method, more if drain plug method but they are using a suction at a dealer therefore $100 labor / .25 hrs actual time needed to complete the job = $400/hr. You would need to dump the oil yourself at some point.
Where am I wrong? Your dealer charged you $46.22 for the very same filter that could be had from Amazon for $26 shipped (I didn't check to see if it could be had elsewhere). The oil you paid 8 x $9.51 a quart for can be had at Home Depot or Walmart for $26 for 5 quarts - am I wrong so far? How is this "Apples to Oranges" and not apples to apples? Could you have brought both of those to the service dept and had them install those? I don't concern myself with what dealers or indi's charge as more often than not they will accept OEM and approved parts bought elsewhere as long as they can make their $$$ on the labor. "Convenience has it's costs" and it should (hence why 7-11 is in business). You got a good deal as far as dealerships go, and a fair deal as far as indi's go, but make no mistake you paid a convenience charge. The parts were @$78 what was left over from your $178 bill would be $100 am I wrong here? Fuzzy math please enlighten me if so. Are "Parts not parts" here? Do dealer parts have some added intrinsic value?
$178 total bill - $78 in parts. Now sorry if I do not add in a mechanic walking to get your car, walking to the parts counter to get said oil filter... how much time was taken to actually to the supposed oil change? You said 19 minutes including everything right? Where's the fuzzy math? Not sure what comparing what others have paid has anything to do with this.. of course they likely paid more, how is that relevant? Again, what you paid is a good price for a dealership oil service, and probably average compared to what an indi would charge, but I stand by my statement that they charged you roughly $400/for the labor when you figure in what you could have bought the parts for elsewhere and how long the service took the mechanic
Jagtoes, thanks for providing a breakdown for comparison. I don't know my local rates and since every dealer is independent they could vary considerably.
Other than that, no comment, I don't spend a lot of time crunching numbers on minor operational costs. If I had my car in for something else I would gladly pay that rate.
Received 10,916 Likes
Went over this with the service manager and the labor time is based on 19 minutes for getting the car , driving into the service bay , suction out the oil, remove and clean filter housing , get new filter cartridge , install , pump in oil , check for leaks and return to lot.
That's his way of providing a rationalization of a (reasonable, in this case) labor charge when someone is actually interested enough to ask.
In reality the $39.95 charge almost certainly has *nothing whatsoever* to do with time spent x posted labor rate. Many routine maintenance jobs are priced that way in the car repair business. $39.95 labor for an oil change, $109.95 labor for a coolant flush, 139.95 labor for a 4 wheel alignment, etc. It has nothing to do with labor time guides, actual time spent on the car, flat rate hours, etc.
If he wanted to be more candid he would've simply replied "That's just what we charge".
Most shops, dealer and indy, use a *variety* of methods to calculate labor charges.....not the least of which is the "Hmmm. That sounds about right" method.
jagtoes (02-13-2016)
Castrol 5W30 @ Home Depot - $25.77 for 5qts you need 2 so $51.50 - .
I couldnt suck my 2014 xkr dry on my best days!
I have a big problem with folks that post conjecture, such as yourself.
If you cant post facts, then please dont post. It can cause others to make costly mistakes.
Jagtoes tried to enlightenon costs. I dont think he was looking to start a sh**storm
I own a 2009 Jaguar XKR....4.2L engine.
Oil Filter @ Amazon is $12.00 for a premium K&N Filter #1014
The Oil for the 2009 Jaguar XKR can be bought at Walmart (Castrol Synthetic) after rebate from Castrol total expense is: $26.00 5W30 for 5 quarts. Then there is usually a rebate for a total of 8 quarts purchased.
http://www.walmart.com/ip/Castrol-10...-5-qt/34997877
Cost to have the oil filter removed, oil drained, oil replaced and new filter installed is $26.00 at any Jiffy Lube with a coupon found on-line that they have every day of the week.
This 2009 Jaguar XKR is nothing special. It is just like any other normal car that has a removable canister filter. Go to their website. It is called "Signature Service".
All the Jiffy lube installers have to do is remove the plastic cover from the underneath, unscrew the old filter, drain the oil, replace the oil filter, fill with oil.
Filter: $12.00
Oil: $29.00 after rebates
Labor: $26.00
Total: $67.00
My local Jaguar dealer (Garcia Jaguar-El Paso, TX) charges $140.00
The brand Jaguar might be a prestige car thus having to pay more for service at a Jaguar dealer than other brands. When it comes down to a basic oil change the Jaguar is just like any other car.
I have used my local Jiffy Lube store for many years. They change the oil in my 2014 Porsche 981, 2009 Jaguar XKR, 2014 Ford F-150 and my wife's 2012 Hyundai Tucson. My 2015 Corvette C7 goes in for the first 4 free oil changes from GM. Then thereafter, you can probably figure out who will be changing the oil in the Corvette in the future.
There is no need to spend unwarranted $$ unless you as an individual feeling better by going to the dealership.
It's your money. I spend mine wisely.
Filter: $12.00
Labor: $26.00
Total: $67.00
Leeper u are way off base. U repeatedly referenced the suction method on this car. This year vehicle is drain plug only.
Amazon.com: K&N HP-1014 Performance Wrench-Off Oil Filter: Automotive
Castrol 10W30 Edge Extended Performance with Titanium Synthetic Motor Oil, 5 qt - Walmart.com
Filter: $12.00
Labor: $26.00
Total: $67.00
Filter: $12.00
Labor: $26.00
Total: $67.00
The last time I was under my 944, for something else, I noticed the bolt and nut holding the pivot for the clutch fork had backed out, allowing the pivot rod to start slipping out of the clutch housing. A quick hit with a blunt object, and re-tighten of the bolt, then the nut, saved being stranded later. (What does puzzle me is why this came loose in the first place, I'll have to keep an eye on it.)
Your service department will vary, my local dealer has NO ONE that understands older Porsches, I do not recommend bringing anything pre 1999 there.
Received 1,123 Likes
We will have to agree to disagree. There is a cost to maintaining a top quality shop specially outfitted with the tools necessary to maintain our cars. Furthermore, the experience of the technicians is what I depend on. The last thing I would ever want to have happen is my local deanship closing down due to a lack of business.
As for an oil change, I'm hopeful your technician gave the car 'a once over' on items not oil change related. Mine always does.
