Mysterious overheating 🤬
Every once in a blue moon my 2010 xk 70,000 miles when in traffic moving at a crawl for 20 mins or so I get engine overheating light so I pull over cool down 30 mins and it’s good happened about 3/4 times in last year always same conditions I’m in Florida so I know it’s hot , can anyone suggest what it might be I’m a green Jaquar owner but love the car had it for 4/5 years now .
Assuming that the coolant level stays full, I would suspect either a faulty temperature sender (which means the system is not actually overheating at all) or a faulty fan, fan controller or relay which means that the coolant is actually getting too hot.
If it never happens when the car is actually moving forward and air is being forced through the radiator, then I would favour a problem with the fan or its control system.
Richard
Richard
Richard
Richard
No. Part swapping is never the answer. Get an Infrared thermometer. Assuming you have no DTC codes thrown, you should be checking the temperature (point the thermometer at the hoses.) if the light comes on. Check to see if your fan is running when the problem occurs. $20 for the tool and your time is all it takes.
it .
It does sound like a fan-related problem but, as Sean says, don't change the fan that will probably be a waste of time and money at this stage.
The easiest things to check first are the fan circuit fuse and the relay. The locations of both can easily be found online or in the manual. It's unlikely to be the fuse but it might have dirty or loose connections and it's easy to check. The relay is more likely and can be easily checked or buy a new one (they are not expensive) or swap it for one that operates the horn, or something else which is not critical, and see if that solves the problem.
If that does not solve the problem and you've checked the radiator is not blocked with leaves or something, then get the OBD codes read as if it is a fault with the fan controller or the fan itself, there might well be a fault code which will identify the problem before you start spending money on parts.
Richard
Richard
If you find that the fan is operational(when the overheating warning gauge warning appears the fans should be running continuously) it could be the thermostat housing has a piece broken off below the thermostat itself and found it's way to the housing above the coolant pump, this partially blocking the coolant flow hence overheating.
This part is called an outlet pipe and includes the temperature sensor and thermostat part no. AJ811793 available from SNG Barratt.
Paul
Paul
The first suspect should be the thermostat and that it is not opening up completely. Change it and check the housing at the same time. Then test it in a pan of boiling water. Not mentioned is the idea that the water pump is slipping under its belt. So has this ever happened before? If you are caught in traffic and the overheat warning happens, beside pulling off to the side of the road and shutting down the engine, its OK to turn up the heat inside the car and open the windows. That helps a lot. I recommend this more than shutting down the engine. Coolant temperature sensors do malfunction and are inexpensive to change, for the do it yourselfers.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
