Nav Disc??
#82
Aleather (11-25-2017)
#83
#84
#85
Same as my Volvo disk, I put it in and "Reading Maps" came up on the screen for about two seconds, then everything was normal. Maps are newer, so I don't see a problem.
#86
I was surprised to still see somewhat limited state coverage on the newer discs. I guess I was assuming Disc A was software update and Disc B would be all 50 states maps on a single disc. Not the case for me, but it's working fine and I've got the other disc in the trunk should the need arise for the other states whilst traveling east.
* Edited to add: I did upgrade to the 2012/2013 OEM Nav discs a while back, and that process added a software update step. Perhaps that step in the process was already completed back then.
Aleather (11-28-2017)
#87
Mine arrived last night, and I had the same experience. I even drove around a bit and stopped to swap discs. Nothing. But the new discs work fine. *
#88
#89
https://www.jaguarforums.com/forum/x...proach-163521/
Queen and Country (11-28-2017)
#90
So, it sounds like when you put in the Volvo DVD for the first time, it never did a software update, but instead, it left the software update from your 2012/2013 OEM DVD. Hmm... I was wonder if on your touch display screen, does it tell you what type of map is loaded, Navteq Maps or TeleAltas Maps. I’m just thinking outloud here, but if this Volvo disk uses Navteq Maps, I could somehow build my own DVD combining my XJ X350 OEM DVD and the Volvo Maps.
#91
I really don’t know where to look, maybe there's an "info" screen somewhere in the navigation system? I read that TomTom merged with TeleAltas and Nokia merged with Navteq a while back, so I’m thinking these maps on the Volvo disk are TeleAltas maps, but I’m reading that TomTom does use both map brands.
#92
The format of the maps for the MMM2 system in the XK, XF, LR2, Volvo's, etc, is TOTALLY DIFFERENT to the Denso system used in the X-Type, S-Type and X350 XJ.
You might find a Toyota/Lexus disc which kind of works in the X-Type, S-Type and X350 XJ, but it'll be even slower and glitchier than the original Jag discs. Been there, done that...
If you have an X-Type, S-Type or X350 XJ, just use the original Jag discs... there is nothing else.
#93
#95
#96
#98
Received 2,012 Likes
Sean W (11-30-2017)
#99
OK, so AFTER I stuck in that Volvo disk, all the maps are updated... BUT!!!!! Now I have NO voice during navigation! The map moves, I still get the Turns and such between the Tach and Speedo, but Not A Peep other than "Drive to the highlighted route and navigation will begin" or whatever.
Of course I tried turning Voice Guidance on and off, I also changed back and forth between English and Weird English.... nothing!
Tell me if I'm missing something (other than voices).
#100
