Need Admin and Forum Member Asst Pls...Jaguar USA Petition
Brake Dust: A Problem That’s Not Really a Problem
And then, in the article
In 2004 I was at an introduction for the reworked 2005 Focus and was accompanied during the driving portion by one of the top Ford engineers. The brake pedal was soft, with a lot more travel at the top than on the original 2000 model, I noted. The engineer explained that Ford gave up the brake feel so it could use different components and reduce complaints about brake dust.
And the most notable adjective used in the article? ... PRISSY
The article is written primarily to question the inclusion of brake dust as a criteria in the JD Power methodology. It points out that Consumer Reports does not include the same criteria. Because ...
“It is something that is annoying that you clean off, but it is not actually a failure of the brakes,”
To be perfectly clear, it is NOT:
...EXCESSiVE, UNACCEPTABLE and COMPLETELY UNECESSARY for this caliber of automobile!
Agree with Bruce, new wheel design and even higher performance makes the problem look worse while the technology has improved over 30 years. My Portfolio has the Alcan brake system, it is fantastic, but alas very dusty. I t only take 2 hours of driving to film up the wheels. I currently have Murcielago in the shop with very expensive carbon fiber rotors they don't have much dust!
I've been kinda silent on this as I'm torn as to what to say. This is obviously not an issue limited to just Jaguar. I've had issues with this on Toyotas, Nissans, various GM products, and Dodge. It's a choice between longevity, noise, and temperature. The brake pads are the primary wear item in a braking system. They dust as they break down.
The brake dust on my Jag is not nearly as bad as it was on my Toyota, and it's about the same as it is on my Nissan. I swapped out my entire braking system to aftermarket on the Nissan and went full ceramic on the pads. Then I swapped the rims out to bronze so that the dust would not be as noticeable. On my Ram, I went to black/silver wheels to hide the brake dust generated by hauling around a trailer that brought my GVWR to 23k lbs. I'm likely to swap the rims on my XKR for the same reason -- I don't want to clean them every weekend.
If there is a vehicle where the dusting is significantly less, I will wholeheartedly look at the design, pad materials, and wheel design. But I'm kind of with Bruce on this one... I don't think there's a solution really that is worth the bother.
I'm not taking up a contrary position to just be contrary, it's just my experience in owning vehicles to date. I tend to be a little more aggressive with mine as well, which is why I think they all dust so much. Well, that and I live half way up the side of a mountain.
Porsche 911 brakes offer low dust and superior performance, someone earlier in this thread mentioned the company that makes them. If you also read the links to some of the Mercedes threads where MBUSA issued a TSB and replaced the pads, the dust was drastically reduced with no negative affects on braking. My Wife's Lexus IS has factory issued low dust pads and they are great. Again, there is no reason to have ultra high dust pads supplied as OEM for street use, low dust yes, ultra high dust no.
I don't know how you can determine what grade of pad we have on our cars, but I'd want to get my facts straight before I insist that the manufacturer has a problem/defect that requires remedy. Perhaps asking them would be a good place to start. I can just see them replying that they already use a fairly low dust pad...and that just might be true!
Not trying to give you a hard time, or derail your effort, but it's obvious that there's no concensous as to whether there even is a problem.
Bruce
#30
Hi Bruce,
I've been blessed to have owned most every make of luxury and sport European car and have been driving for 36 years; based upon what I've seen the Jags XKR pads are very dirty reminding me of the pads that came on our new 2005 Touareg; thankfully within 90 days VW issued a TSB and changed the pads which reduced this nasty stuff by about 50% .
I've also spoken to the service mgr at my dealership and he agreed these pads are very dusty. As I've stated and posted links, MB,Lexus,VW etc have all issued TSB's at one time or another for overly excessive dirty pads and Porsche's are very low dust compared to Jags...Jag could easily do the same...but the only way to get them to act is to make our voices heard which is what I've been trying to do here.
#31
#32
Well, if the Jaguar service manager thinks they're dirty then he might be the perfect advocate to contact Jaguar for pad information. There's probably an engineer somewhere that knows how different pads performed in testing on the car.
I can only offer first-hand race track experience of many Porsche and BMW models, as well as countless other high performance cars, and have on a number of occasions worn completely through a fresh set of pads in a single day while dusting them off in my Supra TT
...running OEM pads mostly, and I honestly couldn't tell you whose pads dusted more. I'm pretty sure it must have been mine since I vaporized them, except that one time they caught fire when the black flag was suddenly thrown and I had to pit without a cool-down lap, but the wheels never looked that bad until they were removed and the brake dust was caked on the inside of the rims! Please forgive the shameless way I made my point about rims making a difference
![](http://i49.photobucket.com/albums/f262/GT2860RS/007_8.jpg)
Bruce
![Stick Out Tongue](https://www.jaguarforums.com/forum/images/smilies/tongue.gif)
![Icon Trophy](https://www.jaguarforums.com/forum/images/smilies/icon_trophy.gif)
Bruce
#33
Hi Bruce,
The Service mgr suggested cermanics but said they would cause clicking when applying the brakes...all Jag has to do is use the same brand/ and type of pads on the 911's and that will be that; someone here ealier in this thread mentioned the name of the company that makes them.
With respect to the TT Supra, I tested one when they first came out, very fast car for the time, I remember when the roof was removed however it was a bit of a flexible flyer. Still like the styling to this day.
#34
What are you driving now? My last car prior to the
12 XKR was an 07 Porsche 997S, very little dust compd to the Jag. I have not tried the armour all spray yet as I don't know what the long term effects would be if that stuff gets on the rotors, last thing I need is a glaze build up that causes squealing. You can read in my post above my dealer suggested ceramics but he said they'll create a clicking upon application, don't want that either. What year is the R your are getting?
#35
