Need advice on coolant pipes
Hi Guys,
Sure enough my 2012 XKR with 32k miles on it started leaking shortly after my CPO replaced the water pump (I assume its increased pressure).
I got to the dealer right as I saw coolant burning off. No overheat light..no low coolant light. It was close.
My service advisor is friendly and normally works with me. In this case, the pipe are not covered as they are plastic (and CPO ran out last month anyway).
Bleed Hose
Upper and Lower coolant pipes.
Install and labor $2400. He said he could get it down to $2k. He said its about 10 hours of labor.
What other pipes should they be doing while they are in there? He say's its best to fix what's broke... I know that I need the hard to get to pipes replaced because they are at the end of their life span. I told him I would reach out to our forum community to find out what other pipes must be replaced while they are in there.
Any advice would be appreciated.
Thanks!
Joe
Bleed Hose
Thanks!
Joe
Hi Guys,
Bleed Hose
Thanks!
Joe
Bleed Hose
Thanks!
Joe
Thanks for your response. I guess these pipes let go around 2,500 miles after the new pump was installed.
AJ813865 is the cross over pipe I believe. That is being changed in addition to a few other tubes and hoses.
I knew these were bound to break. Our high heat down here and the age of the car meant I didn't have long. I guess I'm lucky that it happened in their service entrance.
Joe
Joe
I plumbed my Mustang for life using all stainless braided Teflon lines with AN fittings. Granted these Jags have quite a bit more lines, but if I ever get stuff torn down enough to warrant replacing ANY OEM lines you can bet your butt that I'd NOT use any stock replacement junk. It would probably cost me over $1k in parts to replace ALL with BSS/Teflon, but damned if I'd cheap out if I got that far. Bit by bit repairs, I'd use off-the-shelf rubber hoses with aluminum fittings and worm clamps before I'd use ANY plastic, especially stock Jag stuff. Replacing old junk with newer junk isn't a repair, it's incompetent.
Hi Guys,
Bleed Hose
Thanks!
Joe
Bleed Hose
Thanks!
Joe
Hi Guys,
Thanks!
Joe
Thanks!
Joe
Harry Peter Rose
02-25-2018 06:19 PM
