Need Help | Seatbelt Twisted
Moses, you can use some 'extra' force to try to squeeze the half-bent belt through the buckle. Alternatively (or in addition), you might consider removing seatbelt anchor point on the floor just behind the front seat; but to remove this you will need to remove the seat as the removed hex bolt will hit the seat rail before disengaging completely!
The twist you have was probably there from the start, I think I saw a TSB somewhere; can't believe how these things happen!
Realize this is an older thread...
I got to work today and the drivers belt on my 07 xkr would not retract. Looked and realized it had a half twist between buckle and retractor. I pulled the belt out all the way 3 times but the twist stayed and it didn't want to retract.
So.... with it pulled all the way out I pushed the twist right up to the retractor, lost my grip, and the belt got slurped up and its fine again. The twist must have been behind the rear kick panel.
Hope that helps someone. I'm not sure I could have folded the belt and got it back through the slit in the buckle.
