Need help installing the center grill Growler Emblem please!
So, FINALLY picked up my new to me 2007 XKR last night and LOVE it! (No surprise, of course!)
But, I'd posted earlier that the front emblem wasn't there, in it's place was a matte black 'button', for lack of a better description. When I asked the dealer about it, he said it didn't have the emblem due to the ACC, but, this forum pointed out he was dead wrong, so I purchased one from a local Jag dealer and waited.
When picking up the car last night, I handed him the emblem and when we went out there, he took one look and suggested that I take it into a dealer to have it done, as he wasn't sure how to get the matte black bit off, and didn't want to cause any damage.
Sigh.
So, does one just pop the matte black one off or? The emblem I purchased to install has the double sided tape on there, and two wee posts that should be going through something but....
Oh! And, (stupid newbie question I'm sure but..), is there not a 'central' door locks button in the XKR's? Seems a bit odd that I'd have to hit the unlock button on the remote from inside the car to let someone in the passenger side....
Just pull slightly on the driver's side door handle and it will open the passenger side. By the way, nice lookin' car. Same color as mine including the black air vents. Enjoy!
Just pull slightly on the driver's side door handle and it will open the passenger side.....
To expand on this just a bit.... the driver door handle needs to be in the locked/inset position with the door closed for this to work. OR just reach across and pull the passenger-side handle.
Whoo hoo! Worked like a charm, thanks Cee Jay!
And, thanks Tberg! Apparently, it's the only one in Canada with that color combo
Any thoughts KJ? Looks like it should just be popped off there, but, I don't want to take any chances. The dealer was under the impression that that was the radar for the ACC, so nothing else should be over it but...*scratches head*
Interesting as that does not look like the normal grill emblem. It does look like some type of cover. I would wait until others with your year post on what their mount looks like. Does this car have an aftermarket or replacement grill and if so is the original grill behind the black grill.
Actually, it looks like the growler fell off (from some pictures I've seen on the forum, it looks like some growler emblems are on a 'cup' that fits over that plastic knob).
There are some threads that talk about removing the growler, to replace with a new version.
While in this thread, one member was able to get to the backside of the growler emblem and unscrew it from underneath (read the thread carefully, as there is a mix of comments from owners of different model years): https://www.jaguarforums.com/forum/x...-grill-124141/
It's possible, here's what I got from the dealer....
Front
Back - the white paper on here can be pulled back to expose the double sided tape on the back, and those 2 black bits are the posts that must attach to something on the grill itself
And ah HA, just tried to slide my finger nail under the edge of the silver circle, and it does slide through there. Think you might be onto something there KJ, maybe it's just the 'face' of the emblem that's off....
Is the outside diameter the same as the inner circle of the front black holder. The 2 plastic tabs are to center the emblem. I don't believe the face fell off. You may try to take a piece of dental floss and slip it behind the the part on your car and try to saw down and if it goes half way the just pry the rest off. Clean the area and stick on the new one. Don't know what on the dealer gave you but there are 2 difference sizes. Measure it.
Hi Katmac and welcome to the '07 club. It looks like a PO sprayed the grille including the growler and its surround with a heavy black paint. If it is rubber based, you may be able to carefully peel the paint off the areas you want to be bright.
Ahh, so the grill should be silver then? I don't think it's been sprayed over (the emblem I mean), it's perfectly smooth...looks like the emblem part itself may have been taken off...I do have the replacement ready to go on, just need to figure out a way to pop that thing off and have the proper one put in it's place.
