Hi and hope you are all Okay.
I am working on fixing a 2013 XKR which was involved in an accident from the front right side. I finally managed to get some parts from the dealers, shipped from the UK and I'm still waiting for some more. I'm based in Oman. The items I'm enquiring about are:
1- inner fender front part, passenger side, could anyone provide the part number? Is any of these correct for the year? C2P15681 C2P21375 C2P12150
2- Fender bracket, both RH and LH (I think it fixes the headlights to the fender, see attached pic) does anyone know the part number?
3- There is an electronics part that sits inside the bumper and connects to the sensors, also see pic. Does anyone know the part number and what is it called?
4- The impact damaged some of the extension components of the chassis, I managed to get the parts but I need the rivets. See attached pic. Does anyone know the part number? Any advice?
With the current movement restrictions, its quite difficult to order from the dealers in you don't know the part numbers and there aren't similar cars in breakers yard. Any suggestions would be appreciated.
Thanks, AA Fender bracket Electronics parts inside bumper Rivets
The things that look like tennis rackets are TPMS initiators, they cause the TPMS sensors inside the wheel/tires to transmit. Four total, one in each wheel well. That's about all I know about your post.
Thanks Graham. Appreciated.
EDITED. Found the part, for the benefit of others who might needed in the future its TPMS sensor transponder, a pair LH & RH. P/N C2C24208
1- inner fender front part, passenger side, could anyone provide the part number? Is any of these correct for the year? C2P15681 C2P21375 C2P12150 ......
JLR are notoriously "difficult" about anything to do with body repairs on the aluminium cars. I can't find the rivets in JEPC but they must be an industry standard and available elsewhere.
Thanks again, Graham. I'm after the RH front portion of the liner for which I managed to find the P/N, thank you.
The damage was at the RH side, and I found the replacement parts it's just the rivets that are pending and my technician can't find a replacement. I found these two P/Ns for rivets from SNG Barratt (just searched for rivets, XK) but I'm not sure if they are correct for repairing chassis components. The part no. are: C2C9428 and C2C20590
The rivets are needed for connecting parts 5, 7 and 3, please see attached.
Did you manage to figure out the fender bracket? Its plastic and I think it's fender headlights bracket. Would appreciate it if you could also guide me where to look for that in the EPC.
I'm using the jaguar parts.com site but thinking of buying an offline EPC, any suggestions would be appreciated.
Thank you.
That is ace! Thank you very much. Managed to download a pdf repair manual from the forum but its difficult to navigate and search. Found both sections though. Any chance or having a link for a more interactive version? Aiman
Hi,
I'm struggling to find C2P22599 extension part for XKR 2013. Checked with britcars andthey in turn checked with the dealers the the response is that part no longer available. My car has been in an accident and the part is not repairable. I also sent a request through a breakers yard forum with no luck. Any recommendations? Is it common that spare parts for cars produced in 2015 no longer available from jaguar?
Thanks in advance.
Aiman
..... Is it common that spare parts for cars produced in 2015 no longer available from jaguar? .....
NO but it's likely to be a result of the pandemic. It's not the typical spare for a dealer to hold and they will rely on obtaining from JLR to fulfil their customer order. Jaguar have a Worldwide parts distribution centre in Frankfurt, Germany which will have been closed.
Hi,
Thanks in advance.
Aiman
Not sure where you are located, but a google search for that part brought up numerous hits for online purchase from local dealers. Not sure if the inventory is accurate, but might be worth a look on your own if in the US.
Thanks Graham. I placed the order before the pandemic via my local dealers in Oman, they checked with Dubai then the UK. I will try and check with Germany since the lockdown is easing off there. Thanks again.
