Need new drive shaft; part (C2P16566) discontinued
Need new drive shaft for '07 XK; part (C2P16566) discontinued
Hello folks,
Well, one problem follows another; after replacing the battery on my '07 XK and taking the car on the road I noticed a repetitive *thunking* sound near the rear of car that also causes intense vibrations when accelerating. Not consistent on every ride but definitely worrisome. Took it to the mechanic who confirmed an issue with the driveshaft...
I looked up the part and it appears to be C2P16566...which seems to be discontinued...tried several dealerships and they confirmed obsolete.
Any other options I could try? Any guidance is much appreciated!
Last edited by jdubsFL; 03-21-2024 at 10:41 AM. Reason: Modify topic to add specific model
The following 6 users liked this post by Cee Jay:
David993S (03-22-2024),
guy (03-21-2024),
jahummer (03-21-2024),
McJag222 (03-21-2024),
panthera999 (04-05-2024),
and 1 others liked this post.
Yes listen to jahummer. You might need to replace the Guibo or flexible rubber disc. You will find that Jaguar does NOT sell this separately and will want you to purchase a complete expensive drive shaft.
But it is available from others as a separate part. Hopefully you can find a local shop that is familiar with this.
But here is a thread that might help? He has part numbers too!
Guibo Replacement
If you DIY this make careful note of the bolts and washers to make sure they are put back in EXACTLY the same place as when they were removed. Also be aware that you might well need to re-balance the shaft after replacing the Guibo. But not always.
Guibo Replacement
@jdubsFL what specifically’s failed? Driveshafts rare fail, usually it’s the rubber flex discs which fail and those’re easily replaceable.
Guibo Replacement
Guibo Replacement
The shaft you need shows up from time on time on eBay and salvage sites. Not too hard to locate one. There’s a few on eBay now.
That's one of them, there's a few more for even less.
https://www.ebay.com/itm/23540983663...3ABFBMrrTor8xj
https://www.ebay.com/itm/40485237015...3ABFBMrLTor8xj
Post the pictures if you can? Interested to see what's failed.
I have a hard time seeing what is bad on a drive shaft beyond the Guibo? Since the car has IRS the drive shaft is fixed and just uses these rubber disc's for vibration control because the shaft can't move up and down anymore. No CV joints to go bad?
Several weeks ago while having some work done on my XKR, we had a similar situation on parts of my drive shaft. I am not really sure what the specific part was, but my mechanic called Jaguar, and as previously stated in an above post, Jaguar only sells the entire assembly, no individual components. In doing some research, my mechanic was able to source the part from Mercedes for less than 1/8th the cost of the whole driveshaft from Jag.
This’s the flex disc. There’s a thread about them
on this forum.
https://www.actionmachineinc.com/pro...28521615687732
on this forum.
McJag222 (03-22-2024)
Noma auto parts
Hello folks,
Thank you for all of your feedback and suggestions!
So...upon closer inspection the mechanic ruled out the drive shaft; also, he inspected the flex disc, u-joints, etc. and they look fine. Another suspicion was the rim but since the issue isn't consistent and pops up sporadically he concluded that the rim wasn't the culprit either...
So now we're back to square one. Mechanic is going to do a more thorough inspection.
