Need Underbody Engine Shield 2011 XKRS
Old 06-16-2018, 08:16 AM
Doctodd's Avatar
Exclamation Need Underbody Engine Shield 2011 XKRS
Hello, I am looking for an underbody engine gravel shield for my 2011 XKRS. I am having trouble locating one online. I have found several for the prior body style. There was one used parts store that had one but it is broken already in 2 places, so that doesn't help much. I have drilled holes in mine and have it secured with zip ties, which is working so far. I imagine they will need to be removed for access to change the oil.
I would like to find a new OEM replacement if possible.
Thanks,
Todd
Old 06-16-2018, 08:50 AM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
Thanks,
Todd
Can't help you for sourcing one but as an FYI you don't need to remove the shield to change the oil. That is done from the top of the engine where you hook up a vacuum oil extractor on the nipple under the oil fill cap. Also the oil filter is on the top of the 5.0L engines.
Old 06-16-2018, 08:53 AM
Doctodd's Avatar
Default Thanks for the info.
Thank you for letting me know.
Old 06-16-2018, 09:59 AM
jagtoes's Avatar
Depending on the break you might want to try taking some aluminum flat stock and screw or rivet it as a support.
Old 06-16-2018, 12:39 PM
Stuart S's Avatar
Received 6,285 Likes on 3,449 Posts
+1 on jagtoes' suggestion since it's under the car and not visible. It's an easy DIY fix, will save you $$$, be fully functional and the pan will be stronger than new.
Why buy a new one when there's no guarantee that it won't break just like the first one?
Old 06-16-2018, 02:58 PM
Cee Jay's Avatar
Received 5,360 Likes on 3,174 Posts
Also so you know, without that shield down there the bonnet tends to puff and rattle up and down over 140 mph or so. Therefore, I think it's probably more of an aero piece than a gravel shield.
Old 06-18-2018, 06:44 PM
Doctodd's Avatar
Great!, thank you for your input. I'm all for repairing and saving $. I do have a question about what type of aluminum stock material to use. Are you talking about thicker sheets of aluminum or strips of material? I would think it needs to support some of the weight of the shield.
Thanks,
Todd
Old 06-18-2018, 08:34 PM
Stuart S's Avatar
Because the pan is plastic and was probably designed to be flexible, I would use thin sheet aluminum. First, I would bond it to the inside of the pan with Rhino Glue or JB Weld or other appropriate high temperature adhesive. Second, I would follow up from the outside with some rivets or other fasteners for additional structural integrity in case the adhesive doesn't hold. There's lots of heat down there!
I would avoid adding any significant weight or thickness to the pan.
Old 06-18-2018, 09:26 PM
jagtoes's Avatar
if you have pictures of the damage then more suggestions would be available
Old 06-19-2018, 08:20 PM
Ranchero50's Avatar
I haven't seen that on mine.
Old 06-19-2018, 08:48 PM
Doctodd's Avatar
Are there instructions on how to upload pics? It has been a while since I looked underneath, but I think one of the areas that broke was where it attached to the frame.
Old 06-19-2018, 10:04 PM
ralphwg's Avatar
Received 1,209 Likes on 915 Posts
Uploading is easy there are several icons that appear at the top of the quick reply panel the one that looks like a photo (second from right) is the one you need to click and then follow the instructions.
Johnken
09-01-2017 02:38 PM
JohnEP
10-16-2013 09:30 PM
pezzonovante88
03-28-2011 07:18 PM
whosjk
05-03-2009 08:49 PM
Jon89
04-01-2009 08:21 AM
Quick Reply: Need Underbody Engine Shield 2011 XKRS
