New 2012 Jaguar XKR-S Owner - Is there anything I should know?
One of the only issues with the car is I cant seem to find a unlock button inside the car. For example if I drive up to someone and they want to get into the passenger seat I have to leave over to the passenger door from the drivers seat and unlock the passenger door for them.
Thanks again,
Justin
Thanks again,
Justin
Hi guys,
I have realized in this car that when I remove the key from the ignition or exit the car my phone charger (which has a light) and my radar detector do not shut off. Will they continuously stay on and drain my battery or will they eventually shut off. Right now I am manually plugging and unplugging my radar detector every time I enter or exit the car and that is quite annoying.
Hi guys,
So far all the things I want to do to the car are:
Install a battery maintainer
Install a Curb-Alert unit
(Possibly) Install a Escort Passport 9500ci Radar and Laser Detector + Laser Sifter
Does anyone have any experience with the Curb-Alert or custom installed radar detector and laser shiftier.
Thanks,
Justin
Thanks,
Justin
#28
I have the K40 Calibre front and rear radar detectors + a front laser detector installed in my 12 vert. Which is the third Jaguar I had one in. I am pleased with it. It is not cheap, the installation runs about $2k. I've grown to count on it so much that I feel like I'm driving nude when I'm driving my wife's car. They have a new model out which has more bells and whistles. Here is their website: K40 Radar Detectors and Laser Jammers | K40 Electronics
door locks
I just posted a question about the unlock feature. You will find that, in single point entry mode, when you & your passenger are entering your locked car using keyless entry, the ONLY way to unlock your passenger's door is for YOU to get in, close your door, lock it by pushing the open lever inward, then unlock it by pulling the open lever out. My Jag dealer said that's just the way it is. (Unless you literally reach across and manually open the door, but you still have to be in the car.) Or hit the unlock button on the key fob twice, which, the whole point of keyless entry is, duh, not needing the fob. Does ANYONE have a fix for this, so when you open driver door, all it takes is a flip of lever, rather than get in, close door, lock, unlock?
Hi again. I picked up the car Friday. I am very happy with the purchase. The car is absolutely gorgeous. It looks more like an exotic than a Jaguar. One of the only issues with the car is I cant seem to find a unlock button inside the car. For example if I drive up to someone and they want to get into the passenger seat I have to leave over to the passenger door from the drivers seat and unlock the passenger door for them.
Thanks again,
Justin
Thanks again,
Justin
#30
From inside the car, I reach across and flip the door opener on the passenger side to open the door. from outside the car double click the door open button to open both doors. you can change the way the doors open by changing the program. I forget which screen leads to it but you can download an owners manual. Just type in owners manual in the xk forum and you will find the link to downloading a pdf file. Good luck and welcome aboard.
#32
Originally Posted by jagstin
Hi Everyone,
I know its quite late but attached are some pictures of the car. In my defense it takes time to compile nice shots like these.
Hope you enjoy,
Justin
Hope you enjoy,
Justin
#33
Mine's an '09, but ...
That was my biggest mystery too when I first got mine, but the answer's so obvious, I never found it, because I was looking for a conventional power door lock switch or a button!
Unless there's been a change since '09, the inside chrome door handle itself is the door lock & unlock "switch"!
When you pull up to pick someone up and both doors are locked, gently pull your driver side chrome door handle toward you - not enough to open your door - just enough to bring the chrome handle itself to its 'unlock' position - simultaneously causes the passenger door handle to do the same thing!
Now, since both doors are unlocked, your passenger can easily open their door.
#34
FS[NorthWest]: 20" Kasuga Wheels Set of 4 w/ Pirelli P Zeros
Johncy2000
12-15-2015 08:02 PM
