This is new! Complete battery drain in 4 hours
#41
That recon mode on Ctek does f-all. I found out after I got a dedicated desulphator for $15. But the absolute truth is you will never desulphate a battery past certain point. If you could you would make a fortune turning dead batteries into new. And just like used tire shops you would see used battery shops.
Just for balance, while your point about batteries past recovery is valid, the recon mode on my big Ctek has re-rejuvenated two batteries for me both of which have gone on to give another couple of years of service. Gosh, if only I had known that I could have found a $5 knock-off from AliExpress which would have done a better job - I still would not have bought it.
Cee Jay (05-29-2020)
#42
I can tell you have never actually tired to recondition a bad battery. Or used a dedicated desulphator. Wouldn't that make you biased.
If you did you would see the following. A dedicated desulphator you can hear working, it requires that loud of a frequency pulse. But one could say the ctek uses such ultra frequencies that one cant hear them. However the proof is in the pudding, a battery that is diminished to 25% of its capacity still will charge in 25% of the time it normally requires, after 2 days on CTEK or any other charger/reconditioner product. I.e. no change in capacity. On a dedicated desulphator which takes 4 days- there is a noticeable change in charging time and capacity. What percentage I dont know for certain. But as I mentioned in my post, its not enough to save a battery.
One flaw in your accusation. I own a ctek. Do you own any of the alternatives? And I did say none of them work.
#43
Chill dude.
Queen and Country (05-29-2020)
#45
#46
And the Schumacher that Q&C listed is a perfectly fine brand as an alternate, personally I have had an old-school analog volt needle unit for 15 years that works perfect.
If we are to attack everyone who offers a difference of opinion then most threads won't proceed past the first post.
Certainly Tire (Tyre) threads are chock full of opinion, as are maintainer, oil, wax...you name it.
Chill dude.
#47
The following 5 users liked this post by Stuart S:
guy (06-01-2020),
jahummer (05-29-2020),
jima (05-31-2020),
Marc Voorhees (05-30-2020),
ralphwg (05-29-2020)
#48
It is rich internet righteous condescension at its best.
Some work on current, some work on frequency. But none of them 'work'.
Here is a brilliant and balanced chap, demonstrate that reconditioning does not work.
He used the same charger that I have and the same scenario as Jahummer- a battery on a Ranger Rover that was allowed once to completely discharge. And that is what my post was about- to save him the time, that's all.
Those who complain that its a long video; it was summarized initially as the recon mode does f-all.
#49
The only battery warranty I ever exercised was on an Interstate Battery that was in a car I bought used and they prorated the date stamped on the battery.
Not sure why you are messing around with anything other than getting the battery replaced under warranty. Even if you are able to breathe life into it a new one is much better.
#50
I didn’t recall what specifics they are looking for in honoring the warranty, I did attempt to replace a battery under warranty before and the Midtronics tester they use stated the battery was fine just dead. At the time he mentioned if the tester states bad cells they replace it. Even Optima Battery’s website says bad or dead AGM batteries can be brought back to spec without needing to buy a new battery which is not good for their business if that is the case. I’m just attempting to avoid any hassles if indeed the battery is okay.
So the recon mode took all day after I had already brought the battery to step 8 with the CTEK 5.0. I waited a bit and measured the voltage at 12.53. I let the car sit all night unlocked without the CTEK and measured the voltage again and this time it measured 12.93 🤷🏻♂️
#51
#52
#53
Cee Jay (06-01-2020)
#54
Hallelujah, my Greenville SC Jaguar dealer, Josh/Rafael, after becoming acquainted with my 2016 F-Type R battery drain problem have fully cured the parasitic battery drain by installing 4 updates to the vehicles RFA, GWM, IPC & BCM modules. They could not tell for sure which one solved the battery drain problem but guessed it was the software update to the IPC, [instrument panel ?]. Jaguar does not publish to the dealers what their software update were designed to do unlike what our phone app suppliers do. They also don't pay the dealer for doing software updates under these circumstances.
If you have read my earlier pains and posts, I had a persistent, seemingly unstoppable 2.5 amp battery drain after shut down which was only initiated by plugging in and removing either my BlueDriver OBDII reader or my Allstate Milewise dongles. So Jaguar has a software update which will cure this OBD initiated parasitic battery drain problem on the F-Type.
Thank you ScubaAddict for keeping us focused on this issue and likely for getting Jaguar to address the problem.... and to many others like the TheRock who have helped with interim solutions like a quick and easy battery negative disconnect and AntiGravity Battery replacement. I don't regret installing these two enhancements along the way. AMEN"
Steve Chase, 864-903-5493
#56
I use an ELM327 OBDII Bluetooth reader together with an ancient HTC Droid Incredible phone and the free Torque app to provide virtual Water Temperature and Voltage gauges in my 2013 XJ. I forgot to remove it and the next time I started the engine my dash lit up like a Christmas tree with all the warning lights flashing. Panicked, I immediately drove to my dealer and when my Service Adviser saw that dongle he had a big laugh. He removed the OBDII reader, restarted the engine and all was OK.
Are those F-type software updates you mentioned available for the X150? That's a rhetorical question, as I suspect that no one knows for sure.
#58
actually, all batteries eventually deteriorate. Even Deep Cycle batteries.
https://www.batterybusiness.com.au/b...y-life-and-cca
#59
Leaving a dongle plugged into the OBDII port can cause all sorts of electrical glitches when you start the engine. You should remove the dongle before starting the engine. Ask me how I know. This happened over 5 years ago.
#60
But who knows? Maybe your new dongle won't give you any problems if you leave it in.
There's only one way to find out ...
