New guy needs some assistance
I hooked mine permanently to the auxiliary battery terminals behind the small cover on the left side of the trunk. Positive to the obvious positive terminal there and negative to any convenient bolt or screw. Then all you have to do is connect the permanently installed fly-lead to the lead on the CTEK when you put the car away. It takes about 20 seconds to do it. The CTEK can be left on indefinitely as it has clever circuitry to prevent problems from overcharging etc.
This is the one which, I believe, most of us who have them use:
Here's how I installed mine:
This pic shows the positive terminal behind the cover in the trunk. The rubber cap is in the way - the CTEK fly-lead connector is attached by removing the nut, placing the fly-lead connector and replacing the nut.
This shows where I made the ground connection.
This is all you see in the trunk after installation.
peterv8 (01-21-2020)
Unless you need a new battery again, I'd save the money. Your regular new battery will be fine for the car so long as you either drive the car all the time or use a CTEK (etc) to maintain the battery in good condition. The problems seem to arise when even good batteries are allowed to discharge a little due to lack of use of the vehicle and the Jaguars apparently need a full charge for all their systems to function well. Now you have the tender, your new battery should give you many years of problem free service.
