New (to me) 2007 XK has some niggles
Hi,
I've had my 2007 XK for less than a week now, it has some high miles (88,000) and I'm starting to notice one or two things.
Firstly and most importantly there is the engine. At between about 1200 and 1500 RPM it doesn’t seem to be so smooth. The RPM needle on the dash bounces a little and the accelerator pedal seems to be sluggish. If you are just blipping through that RPM range then you wouldn’t notice a thing. Where should I start looking?
Next I have a couple of electrical issues. The blower motor for the heating/AC has been removed by the previous owner, he is getting a new one for me and going to fit it when it arrives. I don’t know if this has anything to do with anything, but I thought I'd mention it to be complete.
The right rear brake light sometimes works and sometimes doesn’t. I had driven the car for about 40 miles before I got a message on the dash telling me the light was out. Since then I've replaced the bulb, but the new bulb seems to sometimes work and sometimes not.
Finally there is the outside air temp sensor it seems to sometimes work and sometimes not. Sometimes my radio shows 0F sometimes it shows the correct temp. I thought this may be related to the rear brake light???
Any input would be great.
Colin
Colin
Good luck with everything! These are truly fantastic automobiles. And, since Jaguar is the absolute most anthropomorphic auto brand on the planet (as judged by owners worldwide) a few quirks here-and-there lend to each of our Jaguars' personalities.
-e
I am not sure about the brake light, but the 0F ambient air temp is a TSB, as well. Your dealer should be able to find it in the system. There is a computer glitch that displays 0F when the air temp is around 59F. My '07 does that sometimes, as well.
spdracer
10-01-2015 01:43 AM
