New purchase 2007 XK Any Quirks
Hi I'm seriously looking at the 2007 XK convertible as my first Jaguar 2001 XK8 was rear-ended and totalled. The XK8 had the tensioners. I've seen this one has an issue with the dash leather pulling away looking awful, not covered by Jaguar and upwards of $3,500 to have replaced at the dealer. Any thoughts on this or other items to be aware of before pulling the trigger? Thank you.
Markmbaha1 (11-30-2021)
The dash is just the tip of the iceberg. You're considering a 2007 model, which is over 14 years old. Even with low miles, all the rubber parts - bushings, hoses, wiring, etc. - deteriorate with age and may need to be replaced.
As bocatrip said, buy the best preserved example you can find. Don't be in a hurry and search nationally.
Beware of CarFax as you can't rely on them to buy a car - they only report what's been reported to them, and lots of wrecks go unreported. But you can rely on CarFax to not buy a car.
Pay a Jaguar dealer to do a Pre-Purchase Inspection to the Jaguar CPO standards. You'll get a written report of what needs to be done together with an estimate of the repair cost. That PPI can pay for itself, because you can use that report to negotiate a lower price from the seller.
Similarly, get a PPI from a Jaguar-approved body shop for paint and body repairs. The X150 models are all aluminum - the body and the chassis, and require specialized training, knowledge, and equipment to be properly and safely repaired. You can't tell a book by its cover, so while it may appear to be pristine, just remember this: you can put lipstick on a pig, but it's still a pig.
Happy hunting!
Take the time to find "The One".
Happy hunting!
jahummer (12-01-2021)
I purchased my 2007 without a good knowledge of common problems, but I also factored in a $5k repair budget into the price. Other than a bent aerial, there was nothing wrong with the car. Upon a bit of driving, closer inspection, and research, I undertook several preventative maintenance projects, which quickly used up my repair budget. That being said, I'm happy and have a car with new cooling hoses and suspension rubbers, as well as the sealed-for-death fluid changes. Moral of the story: if you're buying any 14-15 year-old used car, make sure you have a plan to keep it sorted.
Markmbaha1 (12-02-2021)
