New Tyres/TPMS
TPMS sensors usually last 5-8 years, so if everything works before the new tires they should work afterwards. If you will go over the 8 year mark before you expect to replace the tires again, you MIGHT consider replacing them now. Use Siemens VDO 53004 sensors if you do.
You should also put your vehicle info in your signature so it'd be easy to reference your production year.
Here in the USA when new tires are mounted, new TPMS valve stem kits are installed at a cost of about $5.00 each tire USD.
JagZilla
02-15-2017 09:18 PM
