New user with 07 XK
Bobioknight (08-06-2016)
Received 1,975 Likes
I did an annual for sure and then break/fix whatever came up in between which there was a few. Cracked transmission oil pan, control modules, leaking AC, and tires are what comes to mind. Make sure to use the correct Castrol motor oil. Actually, it's best to only used OEM and factory specific parts and fluids. Do a brake fluid flush at minimum of every other year. 30k, do the transmission oil pan. Save you doe for the AC fix...
Yes I jumped the gun a bit, been reading a lot of posts that have answered my questions and then some. New to this awesome forum and Jaguar ownership so got a little too excited!
I take my car to the dealer annually for an oil change. They do a very thorough inspection gratis and a great wash job. Agree on bi-annual brake fluid flush also.
I would also recommend replacing the thermostat housing, which has numerous cooling lines attached. It's plastic and not worth risking an overheating engine. You can buy the part online pretty reasonably and I had an indie do my install.
Also, check to make sure that the infamous duck bill is not clogged. Lots of posts on that topic. I use a bent coat hanger to twiddle the duck bill a couple times a year, just to be on the safe side.
Finally, protect the leather dash. I treat mine regularly with Lexol and, in the summer, use a dash cover. It's ugly but keeps the 9 year old leather out of the sun.
I take my car to the dealer annually for an oil change. They do a very thorough inspection gratis and a great wash job. Agree on bi-annual brake fluid flush.
Bob with yours also being a 07 this is the first thing Id be getting changed, as the xk has an absolutely terrible temp gauge (two modes either fine or turn me off due to intense heat) you don't want to become stranded somewhere
Bobioknight (08-07-2016)
The COVERCRAFT ones seem like they are much, much better.
I picked a generic from Canadian Tire for $19 - cut it to fit - works good - dash is much cooler as well as the inside the car.
Bought a second one and cut to fit the side windows too.
You can get a genuine Jaguar logo'd sunscreen for less. See this thread:
https://www.jaguarforums.com/forum/x...nshade-113983/
And in there you'll find this link:
SUNSHADE-WINDSCR | Genuine Jaguar | C2P23638
for $45.94.
for $45.94.
Kevin77 (08-12-2016)
kj07xk (08-08-2016)
