New XKR owner - my thoughts and advice needed
I just picked up a 2011 XKR convertible a few days ago, and it's finally nice to be part of the Jag club. I bought the car in another state and drove it 1200 miles back home. This car is a fantastic grand tourer and a blast to drive. I was surprised at how willing this car is to get to 100+ mph and how much it wants to keep pulling beyond that. I only encountered two minor issues during the trip.
Now that I've gotten my opinions out of the way, I was looking for some advice. I'm planning on getting the fluids changed, including the oil, transmission fluid, and brake fluid. Is there anything else I should look at or any other fluids I should change? I know the water pump is a weak spot of these cars, and unfortunately, I don't have any records to indicate whether the water pump was ever changed. Are there any signs to look out for besides loss of coolant? Thanks in advance.
- The first time I filled up gas, I noticed the label next to the cap said to tighten to 3 clicks. I accidentally did 4 and thought nothing of it, but then the check engine light came on. I'd read about this happening to other people and the car continued to drive spectacularly, so I continued on my way without giving it another thought. The check engine light did eventually go away. I didn't realize the car was this sensitive, but it's a very minor thing in the grand scheme of things.
- A few hours into my drive on the final day, the low tire pressure warning came on. I pulled over at the next convenient spot and checked the tires. They seemed perfectly fine to me. The warning kept going on and off until it eventually went away for good during the final hour of my drive. I don't know if this is the result of faulty electronics or something else. Either way, I'm going to continue monitoring the problem to see if it comes back.
Don't worry about the CEL unless it comes on again.
Your XKR is 9 years old and odds are that the batteries in your TPMS valve stems are dying (or your car battery isn't fully charged). TPMS battery life varies, from 6 - 8 years or more. Your local tire shop can scan them to check the battery life. If only one is bad you should replace all four. No programming is required. Read this thread from the beginning: https://www.jaguarforums.com/forum/x...ensors-107293/
Let your nose be your early warning detection system for your water pump. Always walk to the front of your car after you park it and see if you smell the tell-tale aroma of antifreeze. That's how I discovered my XJs bad water pump.
There should be a code set if the CEL has come on so I would check to see what it was.
I just picked up a 2011 XKR convertible a few days ago, and it's finally nice to be part of the Jag club. I bought the car in another state and drove it 1200 miles back home. This car is a fantastic grand tourer and a blast to drive. I was surprised at how willing this car is to get to 100+ mph and how much it wants to keep pulling beyond that. I only encountered two minor issues during the trip .....
The vehicle is unlikely to have been regularly used for 1200 mile trips at 100+ mph although that is precisely what they were designed to do. Everything up to temperature and fluids circulating freely - not surprising if the odd sensor reported an out-of-range value and tripped the MIL. An SDD diagnostics session would reveal pending and stored codes but I wouldn't worry too much as the vehicle ran well.
The fuel cap cannot be overtightened. The 3 clicks is a precaution to ensure it isn't loose.
With the TPMS, again SDD diagnostics would reveal what happened - the mileage the warning triggered and probably useful supporting detail.
As recommended above, a fluid change is the most important thing. Regardless of what the history shows on a used Jaguar, I always do a complete fluid change to give a reference point for future servicing and to catch up on anything that may have been overlooked.
Enjoy your XKR and enjoy the forums.
It seems like it's a fairly straightforward job to change the engine oil and brake fluid, and I should be able to do that at home. However, the transmission fluid seems a bit more involved, and I'll probably have to take the car in to the dealer to get that done. Overall, how easy would you all say this car is to work on? Are a lot of special tools required?
thesameguy
11-14-2013 04:53 PM
