No power to the intercooler supercharger pump, fuse good
So I got to replacing my intercooler pump with the upgraded Bosch 001 pump. All went well but when testing power with ignition on I got none going to the pump . Any ideas? I checked fuse 24 under the hood, its all good.
Had the car running with new pump and dont notice any flow either. Is there a relay maybe?
08 jag xkr
08 jag xkr
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
08 jag xkr
08 jag xkr
Received 1,176 Likes
I thought the Auxiliary Water Pump was tightly integrated with the Intercooler Circuit and managed by the ECM.
I further thought that the reason for the "Long Drive Cycle Self Test" following a pump change, ensured that once sufficient operating temperatures were reached, all systems were go, or there would be failure codes.
WinterJag
08-17-2013 07:33 PM
