No response from soft top
Received 4,326 Likes
Welcome to the forum - I've moved your post from the X100 to the X150 forum based on the year of your XKR. Members here can best assist with your issue.
As this is your first post, please stop by the New Member section and post an intro - in return, you will receive a warm welcome and some useful tips for forum navigation - enjoy
https://www.jaguarforums.com/forum/n...-intro-must-5/
A couple things to check. Make sure you put the boot top cover in place correctly. Take it out and reinstall. Look t the left edge to make sure the little metal tab is still on as that's what triggers the switch. If that is OK then reset both windows using the procedure in the OM. If it still fails to open then there is a bigger problem. Others will chime in here.
It is unlikely that you broke a connection. Try removing fuse F8 (in fusebox between the rear seats) for 10 seconds and then reinsert it. Hold the button for a good minute and see if it comes back to life.
If not, you will need to follow the manual reset procedure in the owners manual.
FS[Western US]: 03 str mint
mberman
03-21-2018 08:35 AM
