A non-Cambo OBD gauge solution
After having a close call with a valley hose letting go, and NO observable data that something was amiss, I went for one of the cabled OBD gauges. Sorry CabrioBob, I wanted something promptly!
I fashioned a simple bracket which slides snugly between the dash and center console without damaging anything in the process, and removed the existing gauge cover for clearance. It is easily observable from the 3-6 opening in the steering wheel while driving and provides me with the audible warnings as well.
The following 7 users liked this post by mhminnich:
barnsie (11-12-2020),
Cabrio Bob (11-13-2020),
DGL (11-11-2020),
gkubrak (11-11-2020),
ralphwg (11-11-2020),
and 2 others liked this post.
I like how you mounted it- - very clever. I looked at one of these last year but never wanted to have a cable going to the top of the dash; however, I like where you installed it. Can you tell us if it completely shuts down when the car is off. Some devices that connect to the OBD2 port never turn off. The device may go off but still have a low power connection.
I do like the display of mhminnich's unit though. I may install one of these in my daily X-Type.
See it here on eBay
See it here on eBay
I'm in for Cabrio Bob's third round of ADUs. I already use the VGate OBDII Interface that Bob recommends to pair with his unit, but I don't like having to fiddle with the iPhone while driving.
mhminnich, your alternative is certainly cheaper and probably provides a lot of data, but Bob's solution is elegant and attractive. To put it more basically, it's slick as snot!
The following 2 users liked this post by barnsie:
Bill Mack (11-12-2020),
paulgorringe (11-12-2020)
Agreed, but in my XKR the ashtray is already occupied by my backup cam display.
The Autool X50 Plus is the perfect solution at a low price! I just ordered one from Amazon at 5% off.
That's the best solution, but it's waay above my DIY ability level. And the cost difference is substantial, just for the parts. My backup cam was $125 and the Autool X50 Plus was $35, or $160 all in with less than 30 minutes to install both. Sure, it's not the greatest but it works for me.
https://www.amazon.com/dp/B07L8HMKKG..._hpGRFb6RN7236
Hunting around, I found these threads which have similar themes and some additional ideas for adding extra displays.
https://www.jaguarforums.com/forum/x...lgauge-216733/
https://www.jaguarforums.com/forum/x...-gauge-210411/
This is Sean W showing some of the capabilities of his upgrade. It requires that you add a couple of gadgets to the OEM infotainment unit (the unit running the touchscreen). I have NOT attempted this upgrade, so there are others - Sean W, Cee Jay, others I'm sure - much more knowledgeable about how to do it. And there may be other ways to get similar capabilities on your touchscreen display.
All of these solutions start with adding an OBDII scanner to the car. The simplest way to get readouts like this is to install a Bluetooth scanner and an iOS or Android app that shows data on your phone. Simple and cheap, yes, but not as elegant and easy to use as these more sophisticated solutions.
Sean W (11-13-2020)
