Non regular switch off
Annoyed that I could not switch of my XK (2007 model) i experimented with the button. Found that if it is kept depressed for more that 5 seconds, the car will switch off in any position of the gear lever. Good news for moving the car in garage...... as in neutral the parking brake remains off.
BUT! My question is for those who know.
Apparently the assistance of the steering pump is speed dependent. After engine switch off in drive mode, the car can be restarted the button as usual, HOWEVER the steering remains heavy untill next regular switch-off! Why????? Where is teh regulating mechanism to be found??
What else remains in a sort default mode after such switch-off????
Any comments and/or help will be highly appreciated
Welcome to the forum JAG shaker,
I've moved your question from General Tech Help to XK/XKR forum. This is the plce to post technical questions about your model.
Last night I was replacing some burnt lamps in my tail light housings so I'd power up the chassis and then turn it off via the start / stop button without starting it. As I had the hatch open even after the car went back to 'sleep' and the interior lamps went out I could hear the NAV DVD player running and the aspirator fan for the interior temperature was too. They didn't shut down until I closed the hatch and hit the key fob lock. The system just bugged out and didn't go to sleep correctly.
Ranchero50 (05-11-2017)
That makes sense but from a practical perspective neither feature needs to run. The aspirator fan moves air so slowly that I get frozen out of the car if it's warm inside and cool outside on an evening startup. The DVD serves no purpose either since the NAV unit is powered down. Perhaps buggy is the wrong term. Quirky maybe? Either way the car never left convenience mode with the hatch up nor will it with the hood open.
Totally agree that some of the things that stay on during convenience mode are pointless but I wonder why yours doesn't drop out of convenience mode with the hatch and hood open. As an experiment, I have just left both mine open when I got home from work and it had gone to sleep half an hour later, as expected.
