Not planted at speed
Hi. I own a low mileage 2007 Jaguar XKR. It drives really tight with no knocks, vibrations or wobbles.I took the car to a higher speed and it seemed quite floaty, not very confident inspiring. Ive owned a 2013 XJR and that was planted all the way up. The XKR seems a little unstable at higher speeds. Any ideas?
guy (06-26-2023)
Received 2,012 Likes
The following 3 users liked this post by equatorial:
guy (06-26-2023)
I thought that was about the X100 aero stuff. Something else about a bag of golf clubs in the same segment.
markva44 (06-27-2023)
Received 1,123 Likes
the ride would be firm, but with instability… if that makes sense.
And don’t overlook the importance of the anti sway bar bushings.
I concur, at a spirited speed on a winding, rolling road, my car hugs the ground.
I am running 1-2 lbs under pressure in the tires. And i try to have the right rubber for the conditions.
What is a higher speed?
I have an XK and it floats a lot. If I drive in S this lessens the ‘floating’ but it is not planted. From my many questions it seems that the XK is a softer ride than the ‘R’. If you had described the characteristics as dancing or jittery I would look at worn bushings but you didn’t and haven’t mentioned any clunking.
If your elevated speed is over 100mph I would probably look at shocks first and then consider the aero either lifting the front end or the dirty air out back pushing it down (lifting the frontend as a result).
Try diving in S and report back.
wj
wj
markva44 (06-28-2023)
Huge difference between D and S, I suppose.
Yes, spirited driving feels “safer” in S.
On highways (in fact, German autobahn) however, I prefer D.
Even though, at speeds up to 220km/h, no “light” feeling, and I do not really enjoy going any faster.
This is just my experience, consistently with three XKR (4.2) convertibles by now.
