Not the same old AC drain problem
i am aware of the AC drain problem, and have read many threads on this forum. My car has showed no signs of it until the past few days. 2 days ago, I heard a sloshing noise going around sharp curves. But I did not notice any other signs, so thought it was a bag or cargo sliding. However, this morning, I noticed the passenger footwell was wet. I thought this must be the dreaded AC drain clog. I pulled back the carpet, but saw a crack in the black plastic. At first I did not see any leak. Than, I closed all of the vents, put the fan on high and water started to spray out of the crack. Even now, I still have 2 puddles under the car, which makes me believe the drain is not actually clogged. I have a video that illustrates the problem very well. Does anyone have any ideas of:
1. Is there something I can seal the crack with temporarily until I get it fixed? Or permanently?
2. Is this a major/expensive repair? I am guessing, yes!
3. What on earth would have caused this crack?
Thank you all in advance.
wow that is really strange. I would definitely be tempted to try to repair the crack with epoxy or fiberFix https://www.fiberfix.com/ . It's already cracked so there's not much else you can do to damage it.
Not sure what would cause this crack.
Jpav27 (08-23-2015)
I literally made a "band aid" with some absorbent material, some plastic and some tape. It doesn't seem to leak unless the AC is on high. So maybe that will help until I figure out how I want to approach this before I patch it up.
I have been trying to find some diagrams online. But does anyone know, if that plastic area is just the AC housing? Should there normally be water or condensation behind the plastic in that location?
just found this post, what a mess with the dash out, what kind of stupid *** engineered this part.
https://www.jaguarforums.com/forum/x...l-55703/page6/
Jpav27 (08-23-2015)
It's not a complete hole. It's crescent shaped with a portion pushed in a little. It's about the size of an american dime, so larger than a pea. I'll attach pic.
Thanks again everyone
I wish I knew how that crack/hole got there! The car is still fairly new to me. I would have never found the hole if I hadn't thought the water was from a clog in the ac drain. There is no way it was kicked, it's difficult to get to. The scenario I have Invented as a potential cause is: someone was fixing the AC drain and accidentally hit/damaged that area. They didn't think it was a problem, and over time the crack has expanded? That's just a theory.
Thanks again everyone![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
https://www.jaguarforums.com/forum/x...in-fix-135630/
Geez.....
As you say Maybe it got cracked when someone else had the car , if you read the start of this post below some people were hitting theirs to release the problem. IMO this may have what happened, anyway if i was in your shoes i would cut a hole and see could i get at the tube from inside, you could push a pipe through the duck bill, and leave it in and it would drain the water, then fix the hole, it's cracked anyway, what have you got to loose by trying.
I sent the video and a pic to my friend who works at my jaguar service dept. They had a tech take a look. They said to just patch it with some epoxy or RTV.
I don't know enough about cars to go poking around too much. So I will fix the crack and keep an eye on things.
Thank you all for your help. I appreciated the suggestions and links. And thank you all for being patient with me as I learn
You just can't make these things up: since the RTV will take 24hrs to cure. That means I can not use the AC during that time. It is hot here. So, I figured I would just drive my Lexus for a few days. I leave my Lexus at my father's house because he has more garage space. He had company over the weekend, and they had to move my car to get a cart from the garage for a BBQ to put food and drinks on. Apparently, when they moved my Lexus, they left something on in the car and drained my battery
On a positive note, I keep a battery booster in the trunk of the Jag, so I was able to test it. It works great
jumped the Lexus, no problem.
I do not recall where I purchased it, but this is the one I used. I bought this one because it also has the air compressor.
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Amazon.com: Wagan 900 Amp Battery Jumper with Air Compressor: Automotive
I pulled mine and Battery Warehouse carries 22Ah replacements for $54.
Jpav27 (08-26-2015)
Of course, where is the fun in just replacing the car battery? I not only got to test the wagan jump start, but tonight, I got to try the CTek battery tester, and am trying the recondition mode. I am getting to use all of my toys
aholbro1
08-05-2021 05:02 AM
