Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK / XKR ( X150 ) (https://www.jaguarforums.com/forum/xk-xkr-x150-33/)
-   -   OBD2 display in ashtray location (https://www.jaguarforums.com/forum/xk-xkr-x150-33/obd2-display-ashtray-location-233044/)
barnsie 09-24-2020 09:27 AM
Originally Posted by DGL (Post 2293500)
Looks like the update is not taking:
One of the problems Bob has is that his car is, like mine, a 4.2, so he has no way of testing the ADU on the 5.0 cars. It may be that you have encountered an issue with the update that is specific to the 5.0 cars. @MarkyUK is a knowledgeable early adopter of the ADU 5.0 version and reaching out to him may offer you some useful advice.
Just one thing - I am pretty sure you downloaded the correct (5.0 engine) version of the updater, yes?
https://cimg0.ibsrv.net/gimg/www.jag...f93cfe00aa.png
Cabrio Bob 09-24-2020 09:30 AM
Originally Posted by DGL (Post 2293489)
That picture doesn't look like version 2.1.0.5.
What version indicates the startup screen?
I noticed that when errors are occurring, this is due to the ELM327 can't keep up with the request frequency of the device.
About the gallons (and other non-metric units), this is chosen otherwise there are too many variables for me to create an "EZ-update" file.
But you can always try to do it the less convenient way:
- install arduino IDE software
- install ESP32 in the arduino IDE (Additional Boards Manager)
- connect the device to your computer
- select the correct ESP32 board (Boards Manager) and COM port
- download the (not-EZ) Arduino code.
- change the code to your liking's (units)
- upload the code to the ESP32 board
All is explained in the PDF "Manual: software" downloadable from my website (see my signature)
Cabrio Bob 09-24-2020 09:33 AM
https://cimg8.ibsrv.net/gimg/www.jag...2437aa12e6.jpg
can you make a printscreen? I can read the text ...
Cabrio Bob 09-24-2020 09:40 AM
also what the first screen shows where it detects the device, can you show?
barnsie 09-24-2020 09:40 AM
Can you make it out now?
https://cimg9.ibsrv.net/gimg/www.jag...2790f3d18a.png
Rahtok 09-24-2020 09:49 AM
Mine showed up last night! I've got very full work days today and tomorrow, so it'll probably be Saturday or Sunday before I get to all this. But I'm very excited to have coolant temp / warning indicators. :D
Cabrio Bob 09-24-2020 09:51 AM
Thanks Barnsie I can read it.
It looks like it doesn't connect to the ESP32 in a correct way.
Looking at DGL's picture, he has Windows 10,
probably he has to re-download the drivers from this site (windows 10 universal) and install them again.
use a different USB (3.0) port may also help.
It should look like this: (I downloaded the firmware so using the same file)
https://cimg9.ibsrv.net/gimg/www.jag...822daf6f1e.png
https://cimg1.ibsrv.net/gimg/www.jag...ed997cd399.png
Cabrio Bob 09-24-2020 09:54 AM
That's fast ! you were last in the row.
barnsie 09-24-2020 09:55 AM
If you recall, I got a similar sort of error when I first attempted to update my unit and I downloaded the latest Windows drivers, installed them, and it all went smoothly after that. At least, it is worth a try since it only takes a minute and costs nothing. One more thing eliminated from the troubleshooting.
Canadacat 09-24-2020 10:02 AM
I think for now I will stay with the way it is , am very happy just to look down and see temp. Would like to have the warning but can live without it for now.
DGL 09-24-2020 10:03 AM
Drivers are installed. See screen shot.
https://cimg6.ibsrv.net/gimg/www.jag...68374d2551.png
Cabrio Bob 09-24-2020 10:04 AM
The 4.2 code will also work on 5.0 cars.
and 5.0 code also works on a 4.2 car (until you request a screen that should display oil level, you'll get an error)
DGL 09-24-2020 10:05 AM
Keep getting same errors:
https://cimg0.ibsrv.net/gimg/www.jag...120e745440.png
DGL 09-24-2020 10:13 AM
Screen shots of downloaded update file for 5l:
https://cimg1.ibsrv.net/gimg/www.jag...a265712f27.png
https://cimg2.ibsrv.net/gimg/www.jag...998d6f65d7.png
Cabrio Bob 09-24-2020 10:13 AM
strange ... I see "access denied".
Can you check:
- what does the 1st cmd screen show?
- in device manager the COM port of the device (it should show COM3)
- disable bluetooth on your laptop (often seen as a COM port)
- try right-click the firmware.bat file and select "run as administrator".
DGL 09-24-2020 10:18 AM
1st cmd screen:
https://cimg6.ibsrv.net/gimg/www.jag...c3f956ad5c.png
DGL 09-24-2020 10:20 AM
Ran as admin and got this:
https://cimg3.ibsrv.net/gimg/www.jag...42be0396f5.png
DGL 09-24-2020 10:24 AM
Disabled bluetooth, ran as user and as admin still did not update.
Cabrio Bob 09-24-2020 10:27 AM
ok so COM3 is correct.
things that might cause the problem:
- you installed the X64 drivers and you have a X32 computer,
- the esptool.exe file is corrupt: re-download the firmware
- the esptool.exe comes from my computer (X64) an is not suitable for X32 computers.
- you don't have administrator rights on the laptop (very unlikely this causes the problem)
other solutions possible
- disable bluetooth on laptop
- use a different USB port
- use a different USB cable
- use a different computer
- connect the existing USB cable to a power supply (or computer, providing extra power)
DGL 09-24-2020 10:30 AM
Screen shot from device manager showing bluetooth off and device recognizing COM3:
https://cimg5.ibsrv.net/gimg/www.jag...4f2ac8aaa5.png
