OBD2 display in ashtray location
#321
One of the problems Bob has is that his car is, like mine, a 4.2, so he has no way of testing the ADU on the 5.0 cars. It may be that you have encountered an issue with the update that is specific to the 5.0 cars. @MarkyUK is a knowledgeable early adopter of the ADU 5.0 version and reaching out to him may offer you some useful advice.
Just one thing - I am pretty sure you downloaded the correct (5.0 engine) version of the updater, yes?
#322
That picture doesn't look like version 2.1.0.5.
What version indicates the startup screen?
I noticed that when errors are occurring, this is due to the ELM327 can't keep up with the request frequency of the device.
About the gallons (and other non-metric units), this is chosen otherwise there are too many variables for me to create an "EZ-update" file.
But you can always try to do it the less convenient way:
- install arduino IDE software
- install ESP32 in the arduino IDE (Additional Boards Manager)
- connect the device to your computer
- select the correct ESP32 board (Boards Manager) and COM port
- download the (not-EZ) Arduino code.
- change the code to your liking's (units)
- upload the code to the ESP32 board
All is explained in the PDF "Manual: software" downloadable from my website (see my signature)
#323
#324
Cabrio Bob (09-24-2020)
#326
The following 2 users liked this post by Rahtok:
Cabrio Bob (09-24-2020),
DGL (09-24-2020)
#327
Thanks Barnsie I can read it.
It looks like it doesn't connect to the ESP32 in a correct way.
Looking at DGL's picture, he has Windows 10,
probably he has to re-download the drivers from this site (windows 10 universal) and install them again.
use a different USB (3.0) port may also help.
It should look like this: (I downloaded the firmware so using the same file)
#328
#329
#330
#331
#332
and 5.0 code also works on a 4.2 car (until you request a screen that should display oil level, you'll get an error)
#333
#334
#335
strange ... I see "access denied".
Can you check:
- what does the 1st cmd screen show?
- in device manager the COM port of the device (it should show COM3)
- disable bluetooth on your laptop (often seen as a COM port)
- try right-click the firmware.bat file and select "run as administrator".
Can you check:
#336
#337
#338
#339
ok so COM3 is correct.
things that might cause the problem:
- you installed the X64 drivers and you have a X32 computer,
- the esptool.exe file is corrupt: re-download the firmware
- the esptool.exe comes from my computer (X64) an is not suitable for X32 computers.
- you don't have administrator rights on the laptop (very unlikely this causes the problem)
other solutions possible
-disable bluetooth on laptop
- use a different USB port
- use a different USB cable
- use a different computer
- connect the existing USB cable to a power supply (or computer, providing extra power)
#340
