OBD2 display in ashtray location
#341
#342
#343
Cabrio Bob (09-24-2020)
#344
#345
#346
#348
at the back of the device where the display is sticking out, just above that push the black bar with a small screwdriver, the lid can be taken off,
then remove the electronics (not fully - the USB cable prevents this) , flip it over and you can take off the ESP32 by pulling it away from the electronics pcb (mind the orientation when putting it back again)
But first try the other laptop...
#349
#350
#351
or, copy and paste the below code into notepad, save it as a BAT file in the same folder next to the firmware bat file and try to run that.
it's the same as the firmware.bat file but will cause a slower upload to the ESP32 (maybe speed is a problem)
Code:
@echo off setlocal enabledelayedexpansion Echo. REM Echo Files extracted PING localhost -n 2 >NUL Echo. Echo This version will flash the device for 5.0 models Echo. Echo List of COM ports available: Echo. wmic path win32_pnpentity get caption /format:table| find "COM" Echo. PING localhost -n 3 >NUL set "HardwareID=VID_10C4&PID_EA60" set "RegistryPath=HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB" set "ProductName=Silicon Labs CP210x USB to UART Bridge" set "DeviceFound=0" Echo. for /F "delims=" %%I in ('%SystemRoot%\System32\reg.exe QUERY "%RegistryPath%\%HardwareID%" 2^>nul') do call :GetPort "%%I" if "%DeviceFound%" == "0" echo WARNING: Could not find any connected %ProductName%. Echo. endlocal pause goto :EOF :GetPort set "RegistryKey=%~1" if /I not "%RegistryKey:~0,71%" == "%RegistryPath%\%HardwareID%\" goto :EOF for /F "skip=2 tokens=1,3" %%A in ('%SystemRoot%\System32\reg.exe QUERY "%~1\Device Parameters" /v PortName 2^>nul') do ( if /I "%%A" == "PortName" set "SerialPort=%%B" && goto OutputPort ) goto :EOF :OutputPort %SystemRoot%\System32\reg.exe query HKLM\HARDWARE\DEVICEMAP\SERIALCOMM | %SystemRoot%\System32\findstr.exe /E /I /L /C:%SerialPort% >nul if errorlevel 1 goto :EOF set "DeviceFound=1" set "DeviceNumber=%RegistryKey:~-1%" Echo Programmed device will be: %ProductName% on %SerialPort%. Echo. pause CLS :MENU Echo. Echo Version 2.1.0.5 Echo. Echo ------------------------------------------------------ Echo PRESS 1, 2, 3 or 4 to select your units, or 5 to EXIT. Echo ------------------------------------------------------ Echo. Echo 1 - Celsius + Kilometers Echo 2 - Celsius + Miles Echo 3 - Fahrenheit + Kilometers Echo 4 - Fahrenheit + Miles Echo 5 - Exit Echo. SET /P M=Type 1, 2, 3, 4 or 5 then press ENTER: IF %M%==1 GOTO C_K IF %M%==2 GOTO C_M IF %M%==3 GOTO F_K IF %M%==4 GOTO F_M IF %M%==5 GOTO EOF :C_K CLS Echo. Echo. Echo you have chosen Celsius + Kilometers Echo. PING localhost -n 3 >NUL bin\esptool.exe --chip esp32 --port %SerialPort% --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 bin\boot_app0.bin 0x1000 bin\bootloader_dio_80m.bin 0x10000 bin\CK.ino.bin 0x8000 bin\CK.ino.partitions.bin Echo. Echo Cleanup temporary files .... Echo. Echo Finished ^^! Echo. GOTO MENU2 :C_M CLS Echo. Echo. Echo you have chosen Celsius + Miles Echo. PING localhost -n 3 >NUL bin\esptool.exe --chip esp32 --port %SerialPort% --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 bin\boot_app0.bin 0x1000 bin\bootloader_dio_80m.bin 0x10000 bin\CM.ino.bin 0x8000 bin\CM.ino.partitions.bin Echo. Echo Cleanup temporary files .... Echo. Echo Finished ^^! Echo. GOTO MENU2 :F_K CLS Echo. Echo. Echo you have chosen Fahrenheit + Kilometers Echo. PING localhost -n 3 >NUL bin\esptool.exe --chip esp32 --port %SerialPort% --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 bin\boot_app0.bin 0x1000 bin\bootloader_dio_80m.bin 0x10000 bin\FK.ino.bin 0x8000 bin\FK.ino.partitions.bin Echo. Echo Cleanup temporary files .... Echo. Echo Finished ^^! Echo. GOTO MENU2 :F_M CLS Echo. Echo. Echo you have chosen Fahrenheit + Miles Echo. PING localhost -n 3 >NUL bin\esptool.exe --chip esp32 --port %SerialPort% --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 bin\boot_app0.bin 0x1000 bin\bootloader_dio_80m.bin 0x10000 bin\FM.ino.bin 0x8000 bin\FM.ino.partitions.bin Echo. Echo Cleanup temporary files .... Echo. Echo Finished ^^! Echo. GOTO MENU2 :MENU2 pause GOTO EOF :EOF EXIT
#352
#353
#354
#355
#356
Also, are you running the firmware,bat file from inside the ZIP? Bob said this was a no-no and the ZIP should be unzipped to a folder and the batch file run from there. Just random thoughts. Apologies if you have tried these things already.
#357
The error message means you have invalid paths in the path environment - for example, folders which no longer exist. So the batch file is attempting to use a directory it cannot find. Check the full paths for logic and see if that yields a clue. Have you tried moving the ZIP file to the desktop, creating a new folder and then unzipping Bob's file into it? Then swap to that new folder and run the batch file directly from there. Again, apologies if you have already done all this.
#358
#359
Glad you got it done in the end, regardless of how. So, have you installed the ADU in your car yet?
