OBD2 display in ashtray location
#361
1) User error
2) RTFM
3) A poor workman always blames his tools
4) It's the operator not the puter
But seriously, am.glad it worked out for you...in the end
#362
The following 2 users liked this post by DGL:
Cabrio Bob (09-24-2020),
MarkyUK (09-25-2020)
#363
solution probably: use Microsoft software, avoid Microsoft hardware.
DGL (09-24-2020)
#364
More feedback:
The device is a perfect fit and looks OEM. Kudos to Bob. The OBD2 dongle, v-gate, lost connection a few times while I was out for a drive. The led display IMO should be a bit brighter--I had to look hard to see it at night. The placement is excellent making the ashtray useful; however, my right arm is always in the way of glancing at it. As a result, I always need to reposition my arm to check on a reading. This is so much better than using the torque app on my phone.
#365
It sure is. On my long road trips through Europe, I have been using Torque Pro on a second phone (my primary phone is displaying Waze). Mrs Barnsie insists on having her own phone charging and sitting on a magnetic mount shoved into the air vent on her side of the car, so this means I am driving with three phones hanging off my dash! Not an ideal look. Bob's ADU solves one of those problems. And even better, it is permanently there, unlike my Torque Pro app which I only used for long, fast drives. The ADU really does give me peace of mind about my coolant temperature. I will never know why Jaguar denied us this information in the first place - if there was no room for physical gauges, they had plenty of room in the in-dash display for an additional screen showing temperature, volts etc. Most serious car enthusiasts want to know these things IMO!
#366
More feedback:
The dim light at night is personal, I personally have it set a bit brighter also. (you'll have to code this yourself without the EZ-update).
and I'm lucky that I'm left-handed I guess.
#367
I have a general question here. I still LOVE the display, no issues, lost connection once, it restored 20 seconds later. No issues
The oil level though........ How reliable/accurate do we think that is? it is saying I have 1.32 Gallons of oil. I just did an oil change the other day (like 3 days ago), and I put in 7L (1.85 Gallons). There is no oil slick beneath my car, the Electronic dipstick seems to be happy, and the car hasn't blown up. and I have only driven <200 miles, I can't imagine I lost .5Gallons in 3 days. Any thoughts?
Thanks!
Thanks!
#368
Oil level: The OBD2 in the car reports it in liters,
I convert this to gallons by multiplying it by 0.264172.
As for the connection lost, this seems to be a 5.0 model thing. In a next update I'll add 50 milliseconds delay to the data request frequency.
Shipments to USA and Canada:
PostNL made a delay statement on 22 September.
probably also applicable for Canada
Hurricane Sally operates on the southeast coast of the United States, causing heavy rains and flooding in the Florida and Alabama regions. There are no reports of flight cancellations on our scheduled flights, but we do allow for delays when it comes to delivery in these regions.
As previously communicated, we are seeing major delays at the destination USA. Due to limited capacity, the United States Postal Service (USPS) has difficulty handling the high volumes of mail and parcels. In some cases the delay can be as much as 6 weeks. We are aware of the issues facing USPS. We work closely with them every day to get shipments on the best possible routes. While we do our utmost to resolve this as quickly as possible, we remain dependent on our partners. In order to process backlogs as quickly as possible, we also see that shipments are not scanned upon arrival in America. According to the tracking data, the shipment is on its way to the US while it is already there.The next scan event then takes place again when the shipment is processed at the local mail sorting center.
#369
EDIT: From Marc's calculation of 1.85 gallons = 7L, he is using US gallons, so your conversion is, of course, correct.
This is the only forum I use where members can't delete their own posts, which I would have done with this one if it was possible. So an edit will have to suffice.
#370
What you could do is leave the car off for a couple of hours,
get in the car and press the start button without touching the brake pedal.
on the device browse to the oil level screen and have a look at the readings.
barnsie (09-26-2020)
#371
I can imagine that, when the engine is running, it pumps the oil around, leaving less oil in the pan.
#372
The ADU just reads the information that the engine is sending it. I am so glad I have a proper manual dipstick - I have never liked those electronic 'dipsticks'. Only takes some sort of electrical malfunction and who knows what the engine oil level really is? I'd be happy to have both - a proper dipstick *and* the electrical readout on the dash, but not just the latter. I guess I am a bit old-school, but I know when I see an oily mark on a piece of steel that that is actually the oil level.
#373
I'm not tall--only 5'8" on a good day. I keep my seat lowered and back so my view of the display is more horizonal than someone tall. I noticed as I got up the display appeared much brighter without changing anything. Consequently, the display appears dimmer from a lower, more horizontal, point of view. I'm getting use to driving now more with my left arm so my right arm is not in the way. My right arm blocking a direct view probably has something to do with seat position and my height also. Love the ADU and the quality of workmanship.
The following 3 users liked this post by DGL:
#374
#375
Cabrio Bob (09-26-2020)
#376
#377
#378
I changed my oil last week. Removed 7.5 liters and put back 7.5 liters. I also did a lube guard cleaning. I will change the oil again next week to get any left over contaminants out. When I do the change again I will note readings after putting 5, 5.5, 6, 6.5, 7 and 7.5 liters back in, waiting 1 hour between adding oil. I will then check the reading every few days before starting the engine to ensure I have a save amount of oil.
#379
#380
Even the inventor, Bob, calls it, ADU. We have a name for it. Once I get the readings for 5, 5.5, 6, 6.5, 7, and 7.5 liters I'll equate the readings to the actual volume of oil put in. This should be a reliable and accurate indicator of the actual oil volume.
