OBD2 display in ashtray location
#381
My pal, who is a petrolhead of course, got into my car last week. He immediately spotted Bob's device.
"What's that?" said my buddy.
"That is my new ADU," I said.
"ADU?" he replied.
"Auxiliary Display Unit," I said.
I cycled through the different screens, showing off. Just because I could.
"Very nice," he said. "Expensive?"
I just smiled.
"ADU?" he replied.
I just smiled.
The following 4 users liked this post by barnsie:
#382
Got the unit updated to 2.1.0.5 for the 5.0 engine. Updating was easy, and everything went plug n play!
I gotta say, your level of craftsmanship and attention to detail is stunning Bob! This is a beautiful piece of work.
I do suspect a conversion error for the blower pressure. And also suggest that we may want to truncate the decimals from the F temp as it’s scrolling off screen.
The following 3 users liked this post by Rahtok:
#383
Did an oil change today and recorded the readings from the ADU:
5 liters = 4.02 in, 1.32 gal
6 liters = 4.45 in, 1.59 gal
7 liters = 4.84 in, 1.85 gal
7.5 liters = 5.16 in, 1.85 gal
All readings taken on a level hoist. This should give me a good estimate of oil volume in the engine at a stop engine state. Interesting that at 7 and 7.5 liters the gallons gauge shows the same reading. Could this be because the electronic oil check in the car uses it and a reading below 1.85 will indicate to add oil or show oil down .5 liters?
Cabrio Bob (09-28-2020)
#384
The following 7 users liked this post by gmuirnz:
barnsie (09-29-2020),
Cabrio Bob (09-28-2020),
MarkyUK (09-28-2020),
paulgorringe (09-28-2020),
Rahtok (09-28-2020),
and 2 others liked this post.
#385
the device converts this to Bar by dividing it by 100,
then multiplied by 14.5038 to get PSI with 2 decimals.
Concerning coolant temperature, this ought to show no decimals.
If anyone else can confirm this with a 5.0 engine and firmware 2.1.0.5?
Torque custom PID printscreen:
#386
#387
Yes I'm proud of the ashtray 3D design,
no, I'm not proud of my spray painting skills ,
and yes I'm proud of the PCB electronics design since it is the first time I did that .
The Arduino code .... someone who's a pro at that probably will say "what a mess".
#389
#390
Ok here is the 5.0 beta firmware:
EZ_5_0_ESP32_OBD2_2_7_0_beta.zip
changes:
- added differential temperature (2nd last screen)
- beefed up the lowest backlight brightness a little. (increase visibility during night time)
- added code to suppress device startup errors
- increased the data request frequency with 50 milliseconds.
- deliberately set the coolant temperature error indicator to 75°C (167F) so you can see it "in action".
4.2 engines can install this one also for test purposes, just don't scroll past the "distance since codes cleared" screen, or you will get the error.
I'm also wondering what the "boost" screen will show on 5.0 NA engines. Should show an error, or a value close to atmospheric.
changes:
#391
changes:
This is not working. Device goes into error mode, loses connection and shows strange number. Unable to switch to another screen without turning device off.
This could be brighter all the time. I put my finger over the photocell sensor with no change. Did get change before--maybe I just didn't wait long enough.
No startup errors
Connection seemed good. No loss of connection until I reached e-diff screen.
This is working as designed and is a very useful indicator.
Flashed back to prior version pending update.
No startup errors
#392
#393
Ah, there's the problem. There are 1000 millibars in a Bar, and you want to multiply, not divide if you use the way you were thinking.
Net/Net, what I think what you want to do is multiply the millibar reading by 0.0145038. And then the reading I got off of mine would be about 6 lbs of boost at just off idle, which is likely what it should be.
The boost is reported by the OBD2 in millibar (*10),
#394
so getting to BAR is A*10/1000, which is the same as A/100.
I'm now doubting this equation, on this page the same PID 22033e comes up with a totally different equation : ((256*A)+B)/128*.145-14.7 (PSI)
However, this table (csv) shows that PID 22033e comes up with values in kPa. (which is A/100 to get to BAR)
#396
So, after 2 weeks of using Bobs ADU I would like to give an update.
I have updated the ADU to include the coolant alarm which is great but a shame the startup screens were lost/changed.
The peace of mind the unit gives is impossible to quantify, I now drive without worry of whether my car is overheating and about to implode.
The car rarely goes above 93 degrees C even when driven hard which I feel I can do more now I can watch the temperature
I have had very positive comments from friends about the ADU and they cannot believe it is not a genuine Jaguar option but a forum member that has designed and built it from scratch.
I thank Bob from the bottom of my heart for all his work and generosity in building this for a few forum members for such a small outlay.
If Bob was to offer a second batch of these at double the price I would not hesitate in buying one as a spare.
Many thanks Bob
Many thanks Bob
The following 4 users liked this post by paulgorringe:
#397
I've not updated mine for the simple reason of the start up screen, just to see (male) passengers faces light up makes me feel like it's Xmas...females are like 'meh!'
And since the coolant is on the first screen and knowing that over 100 is approaching DWR* zone I can manage that...never managed to get it over 91 and have hard accelerated to 100 to try it out
If ever I sell the car I will replace the ashtray...unless of course the new owner wants to buy it off me for £400...lol
* = Danger Will Robinson!
Cabrio Bob (10-03-2020)
#399
So my review after a week or whatever
Freaking love it. I did the upgrade, start up screen is great (I don't care what it looks like. It works and is awesome). Coolant has been steady at 192-195F (The proper unit of measure :-)) Oil is great and it is amazing. Bob, if no one has bought you a beer yet, come on over to the US, I will take you for a drive and a pint Mate. Amazing
Bonus review: The lights on the OBDII module make my footwell look like a disco while driving late at night (As I just did). Gotta love a good party!
The following 2 users liked this post by Marc Voorhees:
barnsie (10-04-2020),
#400
I'm working on a new update:
- E-diff temperature will now permanently discarded (5.0 engine, 2* proven not to function)
- Coolant temperature will show no decimals (only Rahtok reported the issue wit decimals shown)
- 5.0 engine boost strange values, can't solve this yet (only Rahtok reported this issue)
- coolant high temperature indicator will be also shown on the coolant screen (flashing yellow dot)
Manually set the low brightness setting will not (yet) be implemented, but you can always code this yourself.
Unfortunately, the "old" startup screens can't be brought back in combination with coolant high temperature reporting.
The screen brightness sensor only works past the startup screen.
The "raw arduino code" will be combined for the 5.0 , 4.2 and 3.5 engines.
The "EZ-update" files will stay as is.
The engine type will be Auto-detected.
EDIT: See post #413.
Shipping:
According to my information, only 1 unit has not yet been delivered (wymjym - I saw it arrived in Austin Tx)
Shipping:
