Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK / XKR ( X150 ) (https://www.jaguarforums.com/forum/xk-xkr-x150-33/)
-   -   OBD2 display in ashtray location (https://www.jaguarforums.com/forum/xk-xkr-x150-33/obd2-display-ashtray-location-233044/)
Cabrio Bob 10-06-2020 10:47 PM
Originally Posted by paXKid (Post 2299446)
Cabrio Bob,
I PMed you yesterday asking to be added to round 2, but I am not yet on your list.
Please add, Thanks
Sorry didn't see it.
1 arenaej
2 jtdii123
3 Paulgorringe
4 Retrocket
5 Retrocket
6 Ralphwg
7 StiggyMac
8 TexasTraveler
9 LoudHogRider
10 paXKid
Cabrio Bob 10-06-2020 10:57 PM
Originally Posted by Retrocket (Post 2299531)
arenaej, Sure does look right.. Thanks for responding,
As mentioned, I was influenced by your posted experience w.:Craftcloud. It rang the bells... ease of ordering, polished & dyed, good price, etc, You seemed v. satisfied. Glad to hear that their confirmation follow-up also meets with your expectations, I appreciate that you posted such results.
arenaej, the problem was never Bob's layout or directives; rather it's my own ineptitude in deciphering tech based instructions & procedures. Having little exposure to such tasks, I tend to doubt my execution.
When I opened the file, it seemed sparse in comparison to the illustration... almost none of the dimensions present.
Not knowing if, as viewed, it was sufficiently coded for the Fabricators needs. I figured that I was either missing a step in the process, or
maybe my laptop wasn't showing all the info that was present. I figured, better to ask for guidance, than plow on without conviction.
Would you mind confirming, by walking me through your ordering process.
Was ordering as simple as...
1. I go to Bob's Site and download the Specs for the Procedure.- Z axis Up.
2. I Select a Fab Vendor from supplied list.
3. I upload and transfer Bob's Spec Drawing via Vendor/Fabricator's instructions , and include MJF method & finishing options, desired.
4.-Pay, and await delivery.
Again , is the more detailed info present in the illustration, not needed ?
Bill
Normally the ZIP file downloaded from my site is to be unzipped, and then send the STL's to the company.
But if sending the ZIP works that's also fine.
Adding the note Z-up is optional, and they may ignore it since they may combine a 3D print with others and choose the orientation which suits them the best.
Cabrio Bob 10-06-2020 11:25 PM
Originally Posted by v8moise (Post 2299584)
Here's a quick video I took. https://youtu.be/9wh0217OFhY
Yes the 4.2 engines have less data to read out.
It seems like you should update the device to the latest firmware, this will fix numerous issues, such as a slow responding button.
Update procedure:
- check your Windows operating system (on this site)
- download, unzip and install the ESP32 drivers from my website (either click the X64 or X86 exe file based on your OS)
- connect device to computer (micro USB cable)
- download EZ firmware ZIP file from my website
- unzip the ZIP file
- go into the unzipped folder
- double click the "firmware.bat" file. (Windows might complain)
- follow the on screen directions.
Be sure not to run the "firmware.bat" file from within a WinRAR window.
https://cimg0.ibsrv.net/gimg/www.jag...00fdf1bd04.png
Cabrio Bob 10-06-2020 11:28 PM
Originally Posted by ralphwg (Post 2299622)
The Vgate Icar Pro will not connect with the obd doctor app. However it does connect with Torque Pro. I have been unable to locate any information on this problem either by contacting the address they supply in the package or on the web. Two questions; Any suggestions? Or will this setup work with torque pro. My phone is a Galaxy Note 20.
Ralph
I might not fully understand your question.
My device has nothing to do with a phone, it connects directly to the Vgate iCar.
If you connect to the vGate with your phone, my device can't connect. only one device (or app) at a time can connect to it.
Retrocket 10-07-2020 12:16 AM
Understood, Bob...
It being a zip file explains a lot.... Thanks for clearing the fog.
Every excited user report... every photo of the device in action, makes me even more thankful that you opened it up for a 2nd run.
- Bill.
u102768 10-07-2020 02:08 AM
Originally Posted by Cabrio Bob (Post 2297745)
I'm working on a new update:
- E-diff temperature will now permanently discarded (5.0 engine, 2* proven not to function)
It is such a cool device that you have created so it is a shame you can't get that working. It should be possible because this is what an app on my phone picks up for the diff on my 5 litre XKR:
https://cimg5.ibsrv.net/gimg/www.jag...62564f4624.jpg
ralphwg 10-07-2020 11:48 AM
Bob - Thanks, got it. I was trying to connect it to my phone while waiting for the ADU. Now I understand. Ralph
Cabrio Bob 10-07-2020 11:51 AM
If that app could show which PID it is requesting, I can make it work on my device too.
Cabrio Bob 10-07-2020 11:54 AM
Originally Posted by Cabrio Bob (Post 2298882)
For round 2 I created a "hardware assembly" video, see below.
The firmware update manual better explained will follow later.
https://youtu.be/Qwx9s48ZoWE
The firmware update manual PDF is now finished and can be downloaded from my site at the bottom of the page. (Manual: EZ-updater)
barnsie 10-07-2020 12:08 PM
EDIT: I just checked Bob's site and he doesn't have the earlier FW versions there - only the latest one. If anyone wants the earlier version mentioned below, either ask Bob or as me and I will post it for you. Note: 4.2 litre cars ONLY.
Nice video - thanks.
If you care to update to the next version of Bob's FW, you can have two readings displayed at the same time on the one screen. Very handy. The version you need for this is 21 20 1, which also adjusts the backlight so it doesn't flicker when passing under under streetlights. The version *after* this one flashes the coolant reading screen when a pre-set temperature is exceeded, but this version also makes the start-up screens less attractive (software limitation) and some of us have chosen to stick with 22 20 1 for that reason.
This is what the 'dual display' version looks like..
https://cimg7.ibsrv.net/gimg/www.jag...6a4cbebf2f.png
jtdii123 10-07-2020 12:12 PM
ADU PDF Manual Update
Really well done Bob. I appreciate your attention to detail in all its many forms. Looking forward to getting my 3D printed parts Monday 10/12 from Xeometry . Dongle and low profile cigarette power plug already in hand. Oh wait.... That doesn't sound to well when read back! LOL... Thanks again.
Jim
Cabrio Bob 10-07-2020 12:29 PM
I don't have that amount of space on my website available.
Later I will put the old firmware versions on a google Drive for download.
barnsie 10-07-2020 01:05 PM
No problem, Bob. If anyone wants it, I too am happy to provide it.
Retrocket 10-07-2020 04:44 PM
Bob, I have to hand it to you....
You have "idiot-proofed" every step of the process, for the tech-challenged. (believe me, I qualify for President Emeritus status, in this tired / old sub-set,) lol
From coming out with a video, with fabulously simple steps, when I voiced my assembly concerns... to promising a step-by-step written Instructional... to calming my jitters re: ordering the 3-D Fabricated Body/Top.
( Likewise, the V-gate & USB Sockets were a SNAP.. couldn't be easier; click on the supplied shopping options, and CLICK. IMO, very economical as well.)
Let me tell you... Ordering the 3-D fabricated Parts (used *CraftCloud) was Fast, Simple & **Economical - see below.
(did I say fast & simple.. ordering took about as long as typing this message.)
Note to any Procrastinators, who might be holding back because they're afraid of the process... use your own judgement, but I'd suggest that you Go for it !
I don't believe you'll regret it.
Bob, IMO, thought this through thoroughly, and anticipated every hurdle. He made it a simple, step-by-step, process.
This whole endeavor has been fantastic. A wonderful experience; with a huge payout in the end... Bob's fabulously Customized, OBD2 display.
Thank You, Bob.
Regards, Bill
* CraftCloud ... a thank you shout-out to arenaej, for his help & feedback. It's much appreciated.
**Economical - Ordered 2 units (for my 2 XK's) with Optional Polished / Black dyed finish.
Total : $77. 84 + $5. shipping (I was also able to include a request for "Z axis up" fabrication, if possible)
jtdii123 10-09-2020 02:55 PM
Quick follow up on 3D printed parts from Xometry, a US provider. Parts arrived today. Ordered the two components on October 4th and 5 days later I have them in my hands. SLS PA12 really prints nice. Literally ready to prime, topcoat, and clear coat. Very cool! Cost as delivered was ~$65.
https://cimg7.ibsrv.net/gimg/www.jag...1fa72bd17f.jpg
https://cimg1.ibsrv.net/gimg/www.jag...d7e2b8b2ae.jpg
Cabrio Bob 10-10-2020 01:10 AM
That looks good, as SLS should look like.
G2EOF 10-10-2020 07:34 AM
I am asking €58.50 for the electronics-only device ex shipping.
If you still want to be on the 2nd round list, post it here or send me a private message.
HI Bob, this is one long thread!
Please put me down for one (2010 XK 5.0, Centigrade, Gallons, MPH, PSI, Inches if that's all possible)
Just let me know how and when to pay and I'll send it off to you ...
-Geoff
ArtyH55 10-10-2020 08:45 AM
Hi Bob, could you add me to the list for the device please.
Cabrio Bob 10-10-2020 09:19 AM
-Geoff
Both are added.
Those units are no problem
Units fixed * :
- Gallons
- PSI ***
- Inch
Units easily changeable ** :
- Celsius / Fahrenheit
- Kilometers / Miles
* changeable when you install the full Arduino IDE software
** changeable using the EZ-update utility.
*** currently reports unreliable data (XKR 5.0). Also I received no feedback yet from 5.0 NA (XK) users
See my website in my signature.
Cabrio Bob 10-10-2020 11:54 AM
G2EOF,
I've sent you an email.
couldn't send a private message due to too few posts here
