Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK / XKR ( X150 ) (https://www.jaguarforums.com/forum/xk-xkr-x150-33/)
-   -   OBD2 display in ashtray location (https://www.jaguarforums.com/forum/xk-xkr-x150-33/obd2-display-ashtray-location-233044/)
KMVW 01-26-2022 11:51 AM
Thats great Bob thanks. I was already on the list so please advise how, when and where do we pay you. Also could you let me have a link to your website. Thanks Keith.
Cabrio Bob 01-26-2022 11:53 AM
Website link is in my signature
KMVW 01-26-2022 12:24 PM
So it is - and payment details please Bob.
scjordan1969 01-26-2022 01:15 PM
Hi bob, put me down for one thankyou 👍👍
wsn03 01-26-2022 02:14 PM
Originally Posted by Cabrio Bob (Post 2489706)
Ok here it goes.....
I ordered parts for an additional 9 pieces. When those are reserved, no more units will be made by me.
Parts are estimated to arrive here around the 4th of March.
Since July 2021 we have to pay import duties, so the price of a unit goes up a little.
If you still want one please reply below.
Please note: people who previously showed interest have priority.
final, final round details:
- I will only supply the soldered electronics, the USB cable and the button cap.
- The 3D print you can have it printed yourself using MJF or SLS Nylon technique and (have it) painted or stained.
- For example, select a 3D print service from this list (and download the 3D print zip file from my website).
- The ELM327 "Vgate iCar Pro 4.0 bluetooth" you should order yourself (source 1 (UK) source 2 (US) source 3 (DE) source 4 (Ali))
- Ordering a different type of ELM327 device is not recommended.
- The cig power socket you should order yourself, I got these or these. (or get an other low profile one)
I am asking €63.50 for the electronics-only device, excl. shipping, excl. paypal fees.
Shipment standard with track and trace:
to the UK is €18.50, to the USA is €25.55
Shipment with Proof of sending and receipt (signature), Track & Trace, insured up to €100:
to the UK is €21.00, to the USA is €28.05
It seems that shipping to the USA has become cheaper.
Brilliant Bob, I'll nudge the guys on the other site now
427MikeB 01-27-2022 09:55 AM
Hi Bob,
could you add me to the order list?
many thanks
Cabrio Bob 01-27-2022 12:17 PM
Payment is not due yet, I expect to receive parts in 4 weeks or so.
zoszabo72p 02-02-2022 06:01 PM
Hi Bob!
I managed to put together your project and have tested it with a UNO + Bluetooth module so far.
I ordered the Vgate iCar Pro ELM 327 OBD2 Scanner BT 4.0 (which you recommended).
I tried it today but unfortunately after the connection, I keep getting the ELM STOPPED error.
I see this:
*** ELM327 ***
Clearing input serial buffer
Sending the following command/query: AT D
Received char: A
Received char: T
Received char:
Received char: D
Received char: \r
Received char: \r
Received char: O
Received char: K
Received char: \r
Received char: \r
Received char: >
Delimiter found
All chars received: ATDOK
Sending the following command/query: AT Z
Received char: A
Received char: T
Received char:
Received char: Z
Received char: \r
Received char: \r
Received char: \r
Received char: E
Received char: L
Received char: M
Received char: 3
Received char: 2
Received char: 7
Received char:
Received char: v
All chars received: ATZELM327v
Timeout detected with overflow of 47ms
Sending the following command/query: AT E0
Received char: A
Received char: T
Received char:
Received char: E
Received char: 0
Received char: \r
Received char: O
Received char: K
Received char: \r
Received char: \r
Received char: >
Delimiter found
All chars received: ATE0OK
Sending the following command/query: AT S0
Received char: O
Received char: K
Received char: \r
Received char: \r
Received char: >
Delimiter found
All chars received: OK
Sending the following command/query: AT AL
Received char: O
Received char: K
Received char: \r
Received char: \r
Received char: >
Delimiter found
Sending the following command/query: AT ST 00
Received char: O
Received char: K
Received char: \r
Received char: \r
Received char: >
Delimiter found
Sending the following command/query: AT TP A0
Received char: O
Received char: K
Received char: \r
Received char: \r
Received char: >
Delimiter found
showCoolant
Service: 1
PID: 5
Normal length query detected
Query string: 0105
Sending the following command/query: 0105
Received char: S
Received char: E
Received char: A
Received char: R
Received char: C
Received char: H
Received char: I
Received char: N
Received char: G
Received char: .
Received char: .
Received char: .
Received char: \r
All chars received: SEARCHING
Timeout detected with overflow of 0ms
CoolantC: -1.00
showVolt
Service: 1
PID: 66
Query string: 0142
Sending the following command/query: 0142
Received char: S
Received char: T
Received char: O
Received char: P
Received char: P
Received char: E
Received char: D
Received char: \r
Received char: \r
Received char: >
Delimiter found
All chars received: STOPPED
ELM responded with errror "STOPPED"
Expected response header: 4142
Response not detected
VoltA: 0.00
ELM Error: 6
Do you have any idea what the problem might be?
Thank you very much for your help!
zoszabo72p 02-02-2022 06:22 PM
Hi all,
if someone is still trying to create the project themselves, be sure to use version 2.6.4. For 3.0.1, you receive this error message:
https://cimg7.ibsrv.net/gimg/www.jag...f4cbe01cba.jpg
Cabrio Bob 02-03-2022 11:06 AM
Final, final round order list:
- KMVW
- scjordan1969
- 427MikeB
6 pieces left
My previous post () is still valid:
zoszabo72p,
it looks like you already solved your problem?
The version 3.0.1 you mention must be the ELMduino library.
I haven't tried that version yet.
Initially I started with an Arduino Nano, but changed over to an esp32 devkit v1.
My code is adapted to that.
Since you're running an Arduino UNO you might expect problems with the SSD1283A library (link to arduino forum)
zoszabo72p 02-03-2022 03:12 PM
Hi Bob,
Unfortunately, this has not yet been resolved.
The PowerBroker2 ELMduino 3.0.1 library can be used if 'if (myELM327.status == ELM_SUCCESS)' is replaced by 'if (myELM327.nb_rx_state == ELM_SUCCESS)'.
I also use ESP32 Devkit v1. It also communicates nicely with the Vgate iCar Pro ELM327 ODB2 scanner.
The problem is that all values are 0 or -1 when I try to test in the car.
On the phone, all the data comes nicely in the Torque app, but the Arduino doesn’t get any data.
I’m still trying, but I don’t really have an idea what the problem might be.
https://cimg2.ibsrv.net/gimg/www.jag...65d4f18782.jpg
Cabrio Bob 02-03-2022 10:39 PM
in your profile I see you own a Mazda 6.
This might help:
Find out which OBD protocol your car uses, and set the correct one:
Code:
(class).initializeELM('number');
See here:
https://github.com/PowerBroker2/ELMd...ment-616686169
wymjym 02-04-2022 09:35 AM
Hi Bob,
add me to the list
wj
legacy4cam 02-08-2022 09:18 AM
I'd go for one of these temperature displays also?
Am I too late...??
Ta in advance,
Iain .
Cabrio Bob 02-08-2022 10:08 AM
legacy4cam,
you're not too late.
but others who were interested before do not respond.
Final, final round updated order list:
- KMVW
- scjordan1969
- 427MikeB
- wymjym
- legacy4cam
fxdwg 02-08-2022 03:37 PM
To any fence sitters out there, this unit that Bob has created is really very neat and works with the interior very well. It's great for the peace of mind. Mine has performed flawlessly since I got it. I put the supplied board in the printed holder I had made and plugged it all in. It worked without fuss right immediately and has always worked on a car that's only driven on occasion. It's a 5 star buy.
Cabrio Bob 02-21-2022 11:37 AM
- KMVW
- scjordan1969
- 427MikeB
- wymjym
- legacy4cam
An update,
the parts were delivered early,
I will be able to ship out the 5 units the coming weekend.
DanWilderspin 03-06-2022 07:57 AM
Originally Posted by Cabrio Bob (Post 2499252)
An update,
Hi there what was the upshot in the end with the rpms can it pick them up?
I’d like to use something like this with rpm based 12v triggers for valve based exhausts - so for arguments sake from 2500rpm to 4000rpm enable the 12v trigger.. how hard would this be?
many thanks and keep up the good work
Doctodd 03-06-2022 08:02 AM
I realize I am too late for the ashtray device. I was and am still interested but got busy and forgot to order. Let me know if there is another opportunity, sorry about that.
Todd
Cabrio Bob 03-09-2022 09:51 AM
RPM has never been a problem,
and your idea is easily implemented with a ,
use this kind of sketch,
add to the header to which pin the relay is connected (in this example it is 3):
Code:
const int RELAY_PIN = 3;
in Setup, add the following code:
Code:
pinMode(RELAY_PIN, OUTPUT);
in the loop, add the following:
Code:
if (rpm > 2500 && rpm =< 4000)
digitalWrite(RELAY_PIN, HIGH);
else
digitalWrite(RELAY_PIN, LOW);
