OBDII Code Reader Tool for IOS/Iphone
For $39 (<$30 with a coupon) you can get a code reader from Harbor Freight that will read and reset the P codes (powertrain) on any OBD 2 complaint car. You can look at live data, fuel trims, temperatures, and etc on the cheapo readers. They may not have the hi-res color display of a phone, but they work.
I have had several Bluetooth and wifi OBD interfaces for Android and the iphone. While have I have found that they are more likely to work on Android devices they are flakey. They work with some cars and some phones sometimes. When you need it, it won't work. Consequently I have a cheapo reader in the trunk of each of may cars. They work all the time with any car.
Or this device will plug into the OBD port on your XK and display coolant temperature when the car is running. If your CEL goes on you can use it to read and reset the code. $33.25 including shipping on ebay. I have one on my XK. Works great.
AUTOOL X50 Plus Car OBD2 Smart Digital Early Alarm As ELM327 Fault Code Function
mkmccoy (06-04-2017)
