Odd issue after rear turn signal bulb replacement
Got the indication fault on the dash, that my right rear turn signal was bad. Bought the new bulb, and replaced it. Buttoned it all up, but still getting the dash fault, and the right side signal is still in “ fast mode”. But, the turn signal is flashing OK.
So, how do I get the fault to permanently go away? This began about the same time that I replac3d the battery, with a dealer purchased Jaguar branded battery.
I had the self same problem. The replacement bulb I fitted was a known brand from Halfords.
The solution was to buy a much more expensive, "factory" original bulb from SNG Barratt.
Apparently, the resistance (or impedance?) of the bulb must be within a certain range in order not to register as a failed bulb.
Since I happened to be going past my local JLR dealer, I decided to just get the bulb from them.
Hole Catsh#&#$t Batman, $23. Dollars and change for one bulb!
if it fixes the issue, I will be OK with that though, won’t know until I get back from travels.
Received 1,099 Likes
@justinhill , you're entirely right of course. However, who's to say the replacement bulb was in fact a classic incandescent bulb.
As you know, wattage does not necessarily imply brightness. "Lumens" does. (providing for clarification of others)
There is no need for a Jaguar branded bulb. But a correct bulb type is essential.
Cheers!
Cheers!
justinhill (06-25-2024)
As I said, if it corrects the problem, all good.
My understanding is that the bulb must have a resistance (or an impedance perhaps, which is not the same thing) within a fairly tight range or it is flagged as having blown. e.g. (invented numbers, not measured) perhaps a resistance between 1550-1650 ohms. So if it is actually 1750 ohms it wont be significantly different light output, but will get flagged as a blown bulb. Of course it doesn't have to say JAGUAR on it, but you cant take an test meter into Halfords and go through all the bulbs until you find one within the range limits, because you don't know what they are, and Halfords might object. So the only way to be sure is to buy a Jaguar approved one.
The following 3 users liked this post by McJag222:
Factually correct though kind of misleading in this, fixed-voltage, situation since it sort of implies that increasing resistance would increase power, rather than the opposite,
W = I x V - power is amps x volts. I = V / R - amps is volts divided by resistance. Where V is fixed, increasing R reduces I, and W.
Filmscoreking
03-08-2021 02:06 AM
firetapped
08-04-2011 03:03 PM
