Oil Change ?
I've had my XKR since August and have put on 4k miles and I think it's time for an oil change and I'm looking for suggestions/opinions. Do you guys recommend only taking it to Jag to get the oil changed or is a reputable auto shop fine? Also, I just hit 30k overall and I don't have the service manuals so is there anything that needs to be done (serviced) at 30k? Thanks.
The indy may give you a little more time inspecting the car while on the lift that the dealer may not.
If you have a drain plug/2007-2009 model it's fairly easy to do yourself, and you control all aspects of the job including the oil you put back in it.
I just sprang for the 30,000 mile service on my 2008 xk conv. It cost around $410. I figured it would look good on a car fax and other service records when you go to sell the car. The bill says "Performed 30,000 mile service". Parts list shows they changed the air and pollen filters, wipers, oil and lube. The bill also refers to a part called Maintenance Kit $28.50 whatever that is. I was thinking of changing the air filter myself but when I looked on line it seemed like a lot harder than just unscrewing some cover. I think you had to go through the wheel well. The bill is vague as to what else they do. It says "See service menu for complete itemized list". I never bothered with routine service like this on other cars, but this is my first Jag so its kind of like an investment in its future.
For years I have had the oil changed at 5k mile intervals feeling that it was the least expensive maintenance I could have done on any vehicle. Recently, when I had the 08 XK in for it 30k service the service writer that I have used at my dealer for the last two years advised that it was a waste of money, time and effort and to just follow the Jaguar's recommendations for the service. Given that he is an employee with the local dealer and he is recommending against more often service and better income for the dealer I intend to follow his advice.
aholbro1
08-05-2021 05:02 AM
