Oil Change Interval
Brings this up for any potential answers?
My '05 XK's oil/filter change was easy with open access. I assume that this '08 is similarly easy, AFTER removing the belly pan. Just from peaking under, without raising the car, it seems the belly pan is a two piece job.
Has anyone removed the pan for this purpose? Do I need to remove only the front portion of the pan or, both? Looks like a combinations of fasteners are used, including torx-head to the wheel well housing cover.
I did not see any removable access panels down there. Any advice for the best/easiest access to the oil drain plug/filter? No big hurry, I got an other 7K miles until the next change.
Thanks,
Albert
aholbro1
08-05-2021 05:02 AM
