Which oil filter should I use?
I get my oil and filter changed at my Jag dealer every 10k miles. But in between at the 5k mark I go to a EZ lube or Jiffy. I know these guys use the cheapest filter they can buy so I'd like to bring in my own when I go in. Any suggestions on which filter to buy? Thanks
Napa Gold or Carquest premium are true 'premium filters'.
Very important to stick with a well known name brand. Purolator Mann or Fram, to name a few, are well made and reliable.
Those "private labeled" from big box retailers should be avoided. If they "hype" that it's made by Fram, it does not meet Fram's specs. They stop the assembly line, change materials and manufacture that filter to meet the price point.
The oil filters media is designed to capture a specific size (micron) of engine debris. The microns that are microscopic do not present a problem, nor do those that are so large that they wont pass through moving internal parts. It is those microns that can "wedge" between the internally lubricated components that cause engine wear.
Oil is oil, so long as it meets or exceeds the manufactures requirements. The oil filter is the "kidney" and as such you should pay a few extra dollars and buy the best.
K&N
Used these on 2005 XJ, and currently using these on 2009 XK. Excellent specs and easy to install/remove.
Part HP-1014 Product Specifications Product Style: Oil Filters
Anti Drain Back Valve: Yes
Bypass Valve: Yes
Filter Material: High Flow Premium Media
Gasket Material: Nitrile Rubber
Height: 4.531 in (115 mm)
Outside Diameter: 3 in (76 mm)
PSI Relief Valve: 11-17
Removal Nut: Yes
Style: Canister
Thread Specification: 1-12 In. - UNF-2B
Removal Nut Size: 1 inch
Weight: 0.85 lb (0.39 kg)
Product Box Length: 3.16 in (80 mm)
Product Box Width: 3.16 in (80 mm)
Product Box Height: 4.88 in (124 mm)
Bypass Valve: Yes
Removal Nut: Yes
Style: Canister
Thanks for the input guys. Anyone have experience with Bosch, Royal Purple or K & N? To be clear I'm not trying to save a few bucks on filters, I'd just like to know what to stay away from.
Basically, stick with factory or well known names and avoid odd names that are orange and try to pass Frantz.
I was wondering about this also... do any of you guys buy filters online? Was wondering if anybody has had good experiences with a particular online retailer. Maybe I'm just being paranoid about getting a filter that doesn't actually fit, but it seems that finding matching part numbers is more difficult than I would have thought (Purolator's site, for instance, does not seem to find anything for a 2011 XK, though I'm sure they make a filter that fits).
Checked Baldwin Filters | Home and they have one for the XK. That is what I'll use the next time. They make very high quality filters, perhaps the best....
hawaii (10-24-2013)
Interesting... it seems there are more options for the 4.2L motor than there are for the 5L.
Yeah, I live in the middle of nowhere and buy tons of stuff from Amazon because of it. They only appear to have 2 filters listed for the 2010+ XK though, and one of them is this one:
Since the product description on that page says its for the 07 - 09, it makes me wary. Dunno. Usually Amazon is great for selection... doesn't seem to be the case here though.
Here is an article on "The Best Oil Filters..." Granted, like any article on the internet, proceed cautiously. The brands they recommend do seem to be reasonable.
Best Oil Filter – Compare Reviews and Rankings | Bestcovery
XKCoupe (12-05-2012)
Being that you're changing oil and filter twice as often as Jag recommends, I don't think it makes much difference which one you install.
With past cars I've always used Fram or WIX. With the Jag and age, I now just Jiffylube each 3k.
Vince
