Ok, best tires for 2010+ XKR?
I am running the 20" Takoba (8.5 front and 9.5 rear) wheels and will need new rear tires soon.
Looking specifically at Michelin on Tire Rack and they only list the Michelin Pilot Sport A/S 3 as the proper replacement tire for my car (2012 XKR). Anyone know why they don't list the Super Sports as well?
They sell both the A/S 3 and the Super Sport in my rear size (285/30 ZR20).
Just marketing or am I missing something??
Yeah, Don't worry about the Z rating. But also, I went with 295/30 for the rears. One because it needs more rubber back there... (they spin SO easily, amirite?) and two because Michelin didn't have any in 285/30 anywhere. I did Pilot Super Sports. Because best.
Also, one last opinion: Don't mix/match front/rear tire designs. It can lead to odd behaviors due to grip. Lots of people don't like to replace the rears on a different cadence than the front, even if they're staying with the same tire. I'm of a mind to SOMEWHAT disregard that opinion due to how quickly sports cars/GTs burn through tires but...
So you are saying on a 2012 XKR you can sub 295's for 285's????
I would like to extend my driving season here in the Northeast. No winter driving but it would be nice to have the car on the road earlier in the spring and later in the fall. Since summer tires are not recommended below 40 degrees, I'm looking to put 20" PSS A/S tires on after the car comes out of winter storage. I'm not an overly aggressive driver so the tradeoff in traction should not be an issue. Has anyone had any experience with All-Season tires?
#28
Skeeter, I just replaced my set 2 weeks ago with original equipment Perrelli P7's There is a lot of talk about Michelin PSS and I had them before, I personally get more were out go the P7's for my driving style. They seem a bit more sticky! Good luck and go get a set soon, don't get caught up in the analysis paralysis syndrome Cuz!
I got my XK with the pilot Sport A/S (keep in mind this was almost 3 years ago), and I hated the tires with a passion.
I am an aggressive driver (to say the least) so I put tires to the test regularly. Grip was moderate, which is t be expected from an A/S tire, but my scare came from trying to ride the edge of adhesion. Feedback was basically non-existent, so knowing your tires had actually let go only came from the lump in your throat realizing the nose of the car was not where you told it to be. Made for a very scary and late reaction to the problem....
Has the tire improved since then? Maybe, but I wont go back and invest hard cash to find out till I read otherwise.
Look int the Conti Extreme DWS as a decent alternative.
I would personally like to try the Bridgestone 970AS, as I loved the 960AS compound but hated the tread design. Looks like the 970 got some beefed up tread blocks to solve my initial gripe.
BOL
Vince
BOL
Vince
#31
#32
#33
#34
I have some Conti's on my Merc but they are all about noise, gas mileage and comfort. Every time I have deviated from Michelin's for performance I have been sorry.
There are lesser expensive alternatives - yes. BUT - lets first consider what the tires do; yes? Name one other component that does more the experience of the car - you cannot. Tires are the only component that is engaged 100% of the time. The list of what they do is long, comfort, road feel, stopping grip, acceleration grip, cornering grip, noise, rain, etc. A tire makes such a huge impact to a car that when you really weigh the pro/con it is hard to not justify Michelin.
#35
I am not too bothered about what make or design my tyres are as long as they do their job but I wouldn't have bought my XKR if it had a 1 litre, 4 cylinder engine under the bonnet.
#36
Engines are meaningless if you cant bring it all to a stop quickly and safely.
Not "bothering" about safety make you one of the more dangerous drivers on the road today.
#37
I doubt I could tell the difference between Michelin, Pirelli or Goodyear tyres on my car in normal, day to day driving but I could certainly tell the difference between an engine with 100bhp vs an engine with 400bhp.
#38
#39
That's right... and and engine is meaningless without tires to roll on
#40
If the tyres are doing their job, by definition they should be safe.
My point was mainly that there was obvious perceived value in purchasing our cars - otherwise there are way cheaper options. Why make that investment and not make an equally proportionate investment in the most critical part of the car? Yes, there are cheaper tires. There are also cheaper cars. If finances are prohibiting maintaining the car properly then it's time to make better decisions.
