Open boot - battery dead - key wont work - RESOLVED
Old 03-22-2022, 06:58 AM
extremejag's Avatar
Unhappy Open boot - battery dead - key wont work - RESOLVED
Hi - I have a 2007 XKR. Battery is completely dead and I cannot provide it voltage on either underside or through backseat. The key fob behind the number plate is also not operational. I have drilled hole behind number plate as per suggestions online for when keys locked in boot but no luck (is this method only an option for older XK's?) I cannot seem to find the latch when I insert my screwdriver into the hole.
Any help would be most welcome!
Last edited by GGG; 03-24-2022 at 03:23 AM. Reason: Add 'RESOLVED' to thread title
Old 03-22-2022, 08:54 AM
fxdwg's Avatar
If you have access through the back seat (which it sounds like you do), reach in and hook the emergency trunk release that should be there. It will be a larger yellow handle.
Old 03-22-2022, 09:13 AM
GGG is offline
Received 16,861 Likes on 12,186 Posts
Welcome to the forums extremejag.
PUT THE DRILL AWAY and buy some Locksmiths Graphite. Blow it into the keyhole in the bootlid and gradually insert/twist/remove the emergency key blade in the lock several times until it releases.
Stuart S (03-22-2022)
Old 03-22-2022, 09:16 AM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
Just a question here...... WHY can't you apply voltage from underneath??? That IS the way to do it.
Old 03-22-2022, 10:04 AM
Stuart S's Avatar
Received 6,320 Likes on 3,465 Posts
Cee Jay is right.
Read this old thread from 2012. Note: disregard the replies from owners of earlier X100 models.
Use the remote battery terminals under the left rear fender to get enough juice to use the unlock button on the dash to open the trunk. Then hook up at least a 10 amp battery charger directly to the battery. Note that 5.0L models should attach the negative charger pigtail to a chassis ground and not the negative battery terminal.
https://www.jaguarforums.com/forum/x...n-trunk-87388/
Good luck!
Old 03-22-2022, 10:38 AM
extremejag's Avatar
The AA tried when I had a battery issue before and it was not taking a charge underneath... it was them that showed me the trick from behind the seat...
Old 03-22-2022, 10:40 AM
extremejag's Avatar
Is this only on a convertible?
Old 03-22-2022, 10:42 AM
extremejag's Avatar
Originally Posted by Stuart S
Cee Jay is right.
Good luck!
I think this is what I was doing thru the back seat. The issue is that the battery is completely dead (I think it may have died and gone to heaven) and wont take any charge from another battery
Old 03-22-2022, 10:44 AM
extremejag's Avatar
Hi Graham
It is not that the lock is stuck... its that the whole mechanism is just turning around feely when I put the key in the lock.
Old 03-22-2022, 12:30 PM
guy's Avatar
guy
guy is offline
Received 1,123 Likes on 791 Posts
in order to unlock the car using a fob, and not the key, there just needs to be just 10 v available to the system. Even if the battery is completely gone, attaching a proper charger, (and not a trickle charger )and leaving it attached during the process should do the trick.
The charger becomes the electrical source to the car in lieu of the battery. The only interference I see would be the main fuse.
As Cee Jay states, have a look under the LH fender and you will see a rubber boot. That is the positive terminal under there.
As for the lock barrel on the boot not operational…. that’s the first I’ve ever heard of that. Perhaps a locksmith??
I suppose you could go through the parcel shelf, and sort a clever and pretty way of covering the hole… before cutting.
And do note, I don’t eff around. I use the proper spec’d battery and replace it at the first signs of diminishing value.
Old 03-22-2022, 12:51 PM
extremejag's Avatar
Would not attaching a 12V battery not do the same thing?
Old 03-22-2022, 01:03 PM
extremejag's Avatar
is there an emergency release from the inside of the boot. I am wondering if I can go into the parcel shelf and release from there... there is a small gap I can create between the seats and the parcel shelf...
Old 03-22-2022, 01:20 PM
guy's Avatar
guy
guy is offline
Only if you can guarantee the battery is suitably charged.
Yes, there is a release…
Old 03-22-2022, 01:48 PM
fxdwg's Avatar
As guy just posted the picture of, that's the release I was speaking of. But it is on a convertible. I would think the coupe has it as well, but the way you responded makes me think it does not.
As far as connecting a battery to someplace outside the cabin, it can work IF the vehicle battery isn't truly shorted. If it is, (I've had one like this over the years) you will need a massive charger to overcome the dead short and get voltage to the car. A normal charger or jumper box will not do it.
Is it possible to pull the trim around the rear window down, remove it/crawl over the top of it to then pop open the hatch latch?
Let's clarify- extremejag- do you have a coupe or a convertible?
Old 03-22-2022, 02:46 PM
GGG is offline
..... Let's clarify- extremejag- do you have a coupe or a convertible?
A fundamental question.
Nevertheless, the latch assembly and operating method is the same. It may help to see what you are fighting:
Unlike earlier models, there's no operating rods to backup the electric latch release. The emergency key rotates the arm on the rear of the lock (item 9) which pulls the bowden cable to release the latch (item 2). If the lock is just rotating, you do have a problem.
I don't think UK (European specification) models have the interior pull handle. It's been a while, but when I put someone in the boot, I expect them to stay there.
extremejag (03-22-2022)
Old 03-22-2022, 03:21 PM
extremejag's Avatar
Hi - its a coupe...
I just bought a Noco Boost HD Jump Starter, 2000 Amps to see if that makes a difference. But I think it is shorted.
Fast running out of options though...
Old 03-22-2022, 03:27 PM
extremejag's Avatar
Thanks for the info... I wonder if I was able to take the key lock out whether I can manually pull the cable... Will try the booster power pack when that arrives... if it doesn't work at least I will have a very expensive USB charger.
Old 03-22-2022, 03:39 PM
Cee Jay's Avatar
Originally Posted by extremejag
Hi - its a coupe...
That will supply 200 amps for about two seconds and be totally dead.
As stated above, get an actual CHARGER, the bigger the better.
Trickle, maintain, boost, jump...... those are terms that you do NOT want to go with.
Quit screwing around trying to get something to MAYBE work for cheap. You paid a whole lot for your car so you can pay a whole "lot" for a charger. Do what I did, and I'm sure a lot of other members have done.... you'll need one of these anyway if you get into SDD diagnostics stuff...
This is an actual Battery CHARGER, at Amazon
guy (03-22-2022)
Old 03-22-2022, 04:18 PM
extremejag's Avatar
This is around the same price as the one I got...
Old 03-22-2022, 04:21 PM
extremejag's Avatar
and the same amps... so not sure if any better in reality but I may be completely wrong. I saw on a US video someone using the model I bought to start a XKR from a dead battery.
Quick Reply: Open boot - battery dead - key wont work - RESOLVED
