Opening bonnet dead battery
Is there a way to jump or charge the battery from inside the bonnet (front) of the car? I have a 2008 jaguar XK convertible and my battery is dead. I think I left my only key in the boot. I just need to get the boot open or a way to access the battery I’m pretty sure my key is in there.
thanks
thanks
I haven’t looked real close to how it enters the boot but there is a positive lead that goes from the battery to the power point on the left rear of the boot. Maybe possible to connect to that lead.... look up in the bumper behind the left rear wheel... then of course connect the ground wherever you can...
Received 2,012 Likes
Previously asked and answered. You can:
1. Use the blade key in your Smartkey to unlock the trunk (boot) or
2 Use the remote battery positive terminal in the left rear wheel well to attach a battery charger
See: https://www.jaguarforums.com/forum/x...y-help-212115/
Dont use a charger at all. Go get another battery and use jumper cables from new battery.
Reason is that your battery is toast and you will be buying a new battery as sure as the sun will rise tomorrow.
So why muck about with chargers and all, which may or may not revive a lost battery.
ralphwg (08-31-2019)
I'd parked on top of a lit loading dark and chucked inside on a thunderstorm, hadn't notice I'd left the headlights on.
Battery was dead when I came out the next day.
Now if it is dead just during routine use, yes, I agree.
But if there was a very specific reason for the drain, the battery may be ok.
No, there is no access to the trunk from behind the back seat. It's a solid wall that holds the pop-up roll bars behind each seat and the rear fuse box in the center.
If you don't have the emergency blade key that's in your Smartkey, you can charge the battery by attaching a battery charger to the external remote positive battery terminal located in the right rear wheel well and a chassis ground. See the link in my post #8, above, for details.
Crobertrod (08-31-2019)
Vectorous
05-14-2019 10:29 AM
bretthw
05-02-2015 01:54 PM
