Overheating and smoke
Hey everyone just got a new to me 2007 XKR with 250k kms (yes it's up there) indigo blue with the soft top! So drove it a few times and I noticed one sound like a click that would happen every couple of minutes once the ignition was on... or engine. But one key thing was on the day it overheated, earlier there was a squealing belt noise that increased with speed. This was only affected by throttle and turning my steering didn't change its pitch, so I ruled out the steering motor. Could this be a waterpump failure? When the jag began overheating it starts to produce a lot of steam or smoke from under the engine bay. Any help is greatly appreciated!
The cause should be the belt tensioner is not doing its thing, so the belt is slipping on the water pump. A lot of steam pouring out is over the top. Don' do that again. Buy a water temp gauge that plugs into the OBD2 port, now. You should need a new tensioner, if the belt is still good. Or go all out and change the belt, and water pump as well. Add antifreeze. (coolant)
Thank you, that would be a much cheaper fix than a new water pump.. hopefully that is the issue! I'd like to work on the Jag myself if possible, do you think this would be a feasible job or would you recommend going to a shop that's more knowledgeable?
Changing the tension requires getting to it. That could be the hard part. A good independent garage has the skills to get to it from underneath.
Go there with the part in hand. It doesn't have to come from Jaguar. You may want to show up with the belt as well. They can be inexpensive.
Check the water pump for rotation and leaks. You may want to show up with a cheap pump as well. lol. Keep the bills for returns....
Mikesoja (07-16-2024)
Mikesoja (07-26-2024)
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1070x746/screenshot_20240719_113008_chrome_a60ea54969b660c56f37b71c8f4edd89ec973b83.jpg)
Received 1,160 Likes
You really need to take a look at the workshop manual. Graham has a sticky for it at the top of this forum.
You may have initiated a split valley hose with your overheating episode.
Replacing all coolant hoses is a maintenance requirement and some ignore the valley hoses as its an involved task. Of course, that would be a mistake.
There are two Throttle Body coolant lines under that spot. Take off the intake tubes and the top "T" off the throttle body. You can see/feel down there where the lines are using a flashlight. You can also about see if there are any other wet spots down there from a valley hose problem.
To do this cold, a pressure cap could be used. They are pretty cheap to buy.
guy (07-27-2024)
