P0087 Live readings during restricted performance mode
Just picked up a XKR 2010 5.0 Supercharged, drives fine no issues but when I go on cruises and want to push it, ill get on the throttle
kind of heavy and then enter into a limp mode with restricted performance no check engine light and if I press on the gas itll eventually turn check engine on. When I pull over, turn car off and let sit for 5 min and ecu reset with my reader it drives like nothing every happened and code clears.
I have attached live readings of what I got during this, if anyone can take a look, came to the conclusion its probably a high pressure fuel pump issue, it has good pressure when idle but upon reading forums seems like a fuel pump or high pressure issue. Next option is to have someone can with SDD to really test it is what I heard they can see using that software.
do this first
This may be the cause of your low pressure. If not, things get more expensive.
https://www.youtube.com/watch?v=U0PxtnnYdJs
For the few $ it takes, and often this is the culprit, just go ahead and change it, Delphi has aftermarket economy parts for this. Napa or even eBay these days. I am having hard time finding it on a parts list. I think it is still being used. .
I got the same code and limp mode and the whole 9. Mine is a 2012, but ended up being one of the 2 HPFP's. I have a thread on doing the repair on my profile, its rather DIY. Fuel pump costed me like $115
Received 1,180 Likes
Aarcuda
05-01-2020 05:44 PM
DCJAGMAN
23
01-07-2019 09:11 PM
