P0128
P0128
Got the code and from reading here it needs a new thermostat. Question is where do I get it from? The ones at rockauto, advanced, and autozone do not look like what is in the car. Closest dealer is 2 hours away. Any advice?
For your reading pleasure:
https://www.jaguarforums.com/forum/x...-change-99994/
You should order one from a dealer. Gaudin Jaguar has a good online parts department. Is this for an XK or XKR?
XKs have a plastic thermostat housing that is prone to cracking. The Rs have an aluminum one.
The OEM thermostat is the only one I could find that would fit. Many aftermarket ones are mislabeled.
Chadly (11-14-2014)
If I remember right, it is a relatively easy install. Just remove the engine cover and air intake tubing, remove a few bolts and replace the thermostat. I believe in order to bleed the systrm when filling, you will need to fiddle with the supercharger coolant reservoir, which has its own washer/gasket that must be replaced.
vdpnyc
12-12-2013 03:02 PM
HBintheKeys
23
10-24-2013 12:55 PM
