P0128 -- XKR Coolant Thermostat Change
Now I'm confused. I believe I was instructed to purchase all the items circled in number 9 in this diagram.
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/52503-p0128-xkr-coolant-thermostat-change-f302017.gif?dateline=1377660145)
I actually ordered it from Gaudin and it came out to $311 shipped. But maybe I bought an unnecessary assembly? Do I just need items 6, 7 and 8?
EDIT--I just reread your other posts. I guess you were saying that the whole outlet assembly would only be necessary if it was damaged. I wonder if I can just return that assembly if I don't end up needing it.
I went to the Gaudin site and searched for a 2007 XKR and came up with the two jpg attached.
The first shows a box with numerous parts in it and they all have numbers. Outside the box is the number 11. I ordered the number 11 part which include all the parts inside the box. Number 11 costs $114.76.
I'm not sure why your attached jpg looks different than mine. I never added up all the seperate parts and compared it with the single number 11 costs.
Yeah, you shoulda just ordered number 9 in your jpg.
amcdonal86 (08-28-2013)
#30
In post #12, WhiteXKR mentioned that the SC models with an aluminum crossover do not have the same problems as the NA models with the plastic crossover. Hailers has the NA model, you have the SC model.
What you need is just the thermostat.
NAPA 33948 is the *exact* same as OEM complete with seal.
$20 or so.
$20 or so.
amcdonal86 (09-04-2013)
#32
BTW has anyone had any trouble returning anything to Gaudin Jaguar parts? Their return policy sounds really archaic...
I may just keep this thing and steal the thermostat off it since I might only get $100-150 back by returning it, if I'm even allowed to return it! It is quite a beautiful part, it would look good on a bookshelf!
#33
Double checked that NAPA number because your year is different.
Same number. About $13 at rockauto.
STANT Part # 14748
GATES Part # 33948
All the same, STANT=GATES=NAPA.
#35
BTW, I just bought the supercharger washer. It was $3 at the dealer, and it took them about 10 minutes to locate the part number because it's sort of an obscure part.
I would NOT recommend reusing this part because it actually has a rubber inlay that probably would not seal very well if reused.
#38
Argh.... am I not doing this right? The Stant 14748 I ordered does NOT appear fit the thermostat housing. The original OEM thermostat appears to be a multipiece thermostat.
OEM:
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/57421-p0128-xkr-coolant-thermostat-change-img_20131006_114632_473.jpg?dateline=1381076442)
Stant/Gates/Waxstat:
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/57422-p0128-xkr-coolant-thermostat-change-img_20131006_114835_376.jpg?dateline=1381076442)
Thermostat housing (notice the two notches where the original thermostat sort of clipped in):
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/57423-p0128-xkr-coolant-thermostat-change-img_20131006_114650_026.jpg?dateline=1381076442)
Interestingly, it does seem fairly obvious that the thermostat had failed, as the seal has come apart (it was like that before I even took it out of the thermostat housing):
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/57424-p0128-xkr-coolant-thermostat-change-img_20131006_114640_381.jpg?dateline=1381076442)
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/57425-p0128-xkr-coolant-thermostat-change-img_20131006_114820_728.jpg?dateline=1381076442)
Did I not remove the old thermostat completely? What's going on??
I am really irritated because now my wife has to drive me to work!!
OEM:
#39
#40
My 2007 NON supercharged thermostat is a three piece like the one shown in your hand. I do not see how that STANT could possibly work. Then again, I'm not there to see it in hand.
I'd recommend a factory thermostat and it is a three piece one (counting the spring) that locks under those two 'dogs' in the housing. One of my dogs was also broken off (plastic on non turbo cars).
