P2610 code
Old 04-27-2019, 01:26 PM
britannia's Avatar
Default P2610 code
Started my 2007 XK after being rested for 3 months; got a CHECK message, code reader showed P2610; reset, went away, restarted 2 times, didn't come back (yet).........so will it? , if so, how to Fix!!
Thanks, cheers, Adrian
Old 04-27-2019, 01:54 PM
GGG is offline
Received 16,851 Likes on 12,186 Posts
P2610 is ECM/PCM Internal engine off timer performance. Possible causes are:
1. ECT sensor fault
2. Ambient temperature sensor fault
3. Body processor module fault
4. CAN error
If there are no other DTC's indicating a specific sensor or module fault, it is likely to be a spurious error after the "rest". A good drive and a fully charged battery should be sufficient treatment.
chazaroo
09-17-2020 04:09 AM
pastor
10-23-2017 04:36 PM
carcster
09-29-2016 02:21 AM
MBary
19
07-17-2013 02:30 PM
christer200
05-14-2009 04:40 PM
Quick Reply: P2610 code
