Parasitic Electrical Draw on 2011 Jaguar XKR
I have a parasitic electrical draw on my 2011 Jaguar XKR. Trying to run an inline electrical test but can't find the switch that turns the trunk light off. Need to disable this switch to run the electrical test. 1) Any one know how to get at the switch? 2) Anyone have this problem before and if so what was the solution? Any help much appreciated.
Bear in mind that the car will not drop to minimum drain immediately. First, you must lock the car to get it out of 'convenience mode', or it will take up to 30 mins to fully power down. Even after it is locked, it can take up to 5 mins, or 10 if you have TPMS. It should eventually get down to about 33ma.
A couple of thoughts on any residual drain: a dead battery on the battery-backed alarm sounder or a Tracker.LoJack/whatever, if either of those is fitted.
motorbreath777
12-17-2012 05:21 AM
