Part number for wheel liner bolts
Part number for wheel liner bolts?
There are multiple fasteners used to secure the felt inner wheel liners to the body. I'm having trouble finding the part number for the most common one, with the torx head and no washer.
Does anyone have the correct part number?
Mine look like this:
There's an online site called Terry's Jag that has this part (XR82059), but it's not quite right.
The parts diagram shows an even different fastener, which I have 2 of on each side (C2P3803):
https://parts.jaguarlandroverclassic.../brand/jaguar/
This might not cover our years but give it a shot
http://www.mediafire.com/file/zyy36e...eners.pdf/file
Im the last guy to say go to the dealer......but take one off and go to the dealer. I tried looking for it and this thread was the best result on google, same thing with parts catalogs. I assume you are only missing one or two? If you are like me, it would drive me crazy.
You are looking for a Flanged Torx head bolt. These might be them but cant confirm the size without going to Home Depot hahaha.
https://www.factoryoemparts.com/flan...9aa-33454009aa
Welcome to 'The OCD Club' which we will be renaming 'The CDO Club' because.....CDO is in alphabetical order. You are getting off easy, Im replacing the rear skid plate because of a pre existing crack I found while doing the water pump.
I had the same problem seems bolt is replaced by the one in your second picture
In the JEPC I find this diagram;
Can you tell me which number your looking for?
I "think" it's number 4 or 5?
#4 - C2P3803. This number matches what you found. So not the correct one either?
#5 - It's called a plastic rivet so I don't think this is the one? XR87606
#6 - Also another plastic rivet? C2C3564
#8 - Called a plastic nut - XR846656 or XR87606 depending you the car's VIN.
I don't see any other bolts?
I can sort of understand when people are driven to have everything concourse, but that certainly isn't me. Super certainly when parts will never be seen. Add more certainly when OEM parts are literally ten-times the price of actually better quality replacements.
Sean W (02-06-2022)
I 'split the baby' so to speak. If I need to replace something and aftermarket is better quality, I go aftermarket. Coolant pump is a great example, aftermarket is a two piece pump vs Jags three piece. As far as fasteners....Im with the OP on this one as it makes working on the car easier.
I took my arch liners out to replace the air filters over the holidays, several of these were so tight/rusted that the head just got chewed up by the Torx driver. I had to drill them out. I just replaced them with M5 hex nuts and in some cases, replaced the spring clips with stainless steel ones.
Stuart S (02-13-2022)
That’s the motto of the main dealer, sadly. Now that I do everything myself, I don’t have that problem. Seriously, missing or mismatched screws and bolts and then try to order from parts.
had the exact same issue with liner screws. Parts told me they were replaced by the 2-piece slotted torx in the OP’s post.
