Part numbers for rear subframe isolator bushes
Sabrinaservicewriter (03-07-2022)
Good Morning Jahummer!
I did a quick search using our parts distributors look up system and found these two insulator part numbers: C2C16377-Differential Mount Insulator & C2C8221-Differential Housing Insulator. Hope this helps!
Additional Notes: Not sure if you need these but this is from our parts look up system we use. Grant it, a lot of parts on here get superseded.
Rear Axle
Axle Seals
Side Seals- XR821244
Pinion Seal- C2S52518
Companion Flange- C2C32944
Rear Axle
Axle Seals
Last edited by Sabrinaservicewriter; 03-07-2022 at 08:38 AM. Reason: Additional notes
The following 2 users liked this post by Bill400:
kj07xk (03-07-2022),
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/698x874/xkr_diff_image_f09852920cc0c0c58d0e45e260158264bb76cd1e.jpg)
XKR shown XK similar for bushings
XKR Differential Bushings
- 8. Insulator
- differential
- LH upper
- From VIN (B32753) To VIN (B48619)
- 5.0 Litre supercharged
- C2P15558, quantity on the car 1 pc.
- From VIN (B48620)
- RH upper
- C2P15557, quantity on the car 1 pc.
- From VIN (B48620)
- 5. Insulator
- differential
- LH lower
- From VIN (B48168)
- C2D45334, quantity on the car 1 pc.
- LH upper
- To VIN (B48167)
- C2P13646, quantity on the car 1 pc.
- To VIN (B52040)
- 5.0 Litre naturally aspirated
- Other Option
- RH lower
- From VIN (B48168)
- C2D45333, quantity on the car 1 pc.
- RH upper
- To VIN (B48167)
- C2P12732, quantity on the car 1 pc.
- To VIN (B52040)
- Other Option
- 9. Insulator
- differential
- front upper
- C2C8221, quantity on the car 1 pc.
When rubber bushings are NLA you can make your own from liquid polyurethane and hardener. Or purchase universal polyurethane top-hat bushes.
Melb2018
07-10-2019 12:15 AM
Jagluvr
06-07-2018 04:47 PM
