Passenger door difficult to open
Received 2,626 Likes
Does it pull hard from the inside handle as well or at least feel different from the drivers inside handle? If the same condition exists from both locations I would suspect the door latch since it is common to both. I'm pretty sure cables are used to operate the door latch from each of the handles.
Though I have no experience in dealing with this issue, it may be an indication the latch unit is wearing out. There are also electrics and solenoids assosicated with the lock system but I don't see how that would have an effect on latch release.
If closing is OK then there is probably an issue with the release mechanism or sticking to the weather stripping.
If both opening and closing are difficult look for evidence of wear on the striker on the door jamb. That indicates a door, latch, or striker alignment problem, which is a sign of bodywork and can be a real PITA to solve.
If the latch won't physically release easily I'm going with misalignment of the stud to latch or gummed up latch. Inspect the stud. If it's wearing heavy on one side it may need adjusted or the hing pins may have worn.
It's kind of funny / sad that the passenger doors take a beating but the drivers stay OK in spite of being opened more often.
Inevitably I have to remind passengers to desist from using the door window to close the door. Years ago my daughter had a Subaru Outback with frameless windows when she was in college. Eventually every window mechanism had to be replaced at a total cost of $900 on a $22K car. Lesson learned by all involved.
Mine has the same issue on the drivers side. About 3 out of 5 pulls on the outside handle is hard. Locked or unlocked, same deal.. The rest of the time it's smooth as butter. Inside handle opens easily with no extra force every time. I was actually going to take off the door panel and look inside today but got sidetracked...
Anyways, no I haven't got the panel off yet but I did spray some lithium grease in and around the inside of the door latch. Seems to be better but it's only been a few days...
I'll try Graham's solution as well.
chuckjag
04-16-2017 09:45 AM
GrafShutka
11-19-2010 08:12 AM
